c1242 abs code need help
Old Dec 2, 2008 | 10:56 PM
tonycorvettes's Avatar
tonycorvettes
Default c1242 abs code need help
Using J 39200 DMM, measure resistance between BPMV internal connector terminal 8 and motor ground stud.
is what this is saying is to unplug the big connector on the ebcm set it aside and touch pin 8 inside the internal connector and read with an olm meter one side to grd and you should read about 8000 olhms or less?
Old Dec 2, 2008 | 11:30 PM
lucky131969's Avatar
lucky131969
First of all, the procedure you are using is from a 2000 service manual(or older), not for a 2001. Second, the procedure you are using states the resistance value should be .2 - 10 ohms, so I don't know where you are getting 8000 ohms from
Old Dec 2, 2008 | 11:45 PM
lucky131969
Here's why the procedure you are using won't work. On a 2000(or earlier) the ground is a hard ground(not switched). So using this procedure, you are reading through the motor to see if it has opened up.
http://www.flickr.com/photos/1545929...30000/sizes/l/
On a 2001, the ground for the pump motor is switched; thus, you cannot read through the motor the way you are doing it, unless the pump motor control switch is closed.
http://www.flickr.com/photos/1545929...96359/sizes/l/
Old Dec 3, 2008 | 12:12 PM
tonycorvettes
Default im so confuseddddddddddddddddddddd
this is a 2001 ....bottom line is i had my ebcm tested by absfixers put it back ,now im getting only a 1242 code,,would you think my pump is bad?how can i test it ?or what else can i check short of having a teck 11 ?i checked the ground points ans fuse 52 and i have a permanent grd on the pigtail at g with it unpluges ,l ,,,,and 12v on a of the terminal strip do ,,looking into the ebcm g and a i seee nothing no potential,,,one funny thing i have noticed is this,,when i unscrew the nut on the ground lug on the lh rail it has a connector with 4 black wires and one solo blk wire with an eyelet,,when i ground one side of my vom meter and put the other side on the 4 blk wires i see a ground looking toward the harness why?is this ok,,i opened them u and found that one of the wires has a permanent ground,this seems funny to me,,if it needs a ground from the lh rail ,why does it have a grd already?nalrc
Old Dec 3, 2008 | 01:00 PM
byronhunter's Avatar
byronhunter
'02 manual shows one of the wires in G101 tied directly into G102. That would explain why one of the wires shows ground even when disconected from the G101 connector.
Old Dec 3, 2008 | 01:21 PM
lucky131969
Ok, but we are looking at G103 and G108.
Old Dec 3, 2008 | 01:27 PM
lucky131969
Have you looked over the 2001 wiring diagram that I posted? If you cannot follow it, I can help. Let me know....I'll PM my phone number.
Look at the diagram for the 2001 EBCM. Notice that at Pin G, the ground for the pump is supplied via a switch(pump motor control inside the EBCM). If this switch is not closed, you will read an open(or no voltage). Additionally, if the switched battery system voltage has not actuated, then 12 volts will not be applied to the pump. This is why a tech 2 is required to manually activate the pump. Finally, the harness side of the connector should always have a ground on pins G and F.
What is the resistance value of the grounds measured at G and F?
Also, have you checked fuse #5?
Old Dec 3, 2008 | 01:41 PM
byronhunter
Sorry bout that Lucky, my mistake, ok?
Old Dec 3, 2008 | 01:45 PM
Bill Dearborn's Avatar
Bill Dearborn
This is what I told you in my PM yesterday. Based on the updated circuitry the C1242 code doesn't imply an open BPMV ground circuit as it did previously. That is why you need to follow the diagnostic for the year car you have. The code lists posted on the internet can be very misleading.
With the EBCM in your hand you should get an open circuit if you measure through Pin G. Pin G connects the ground wire from G103 (the lug you found attached to the frame along with the splice pack) to the internal ground switch in the EBCM. The other side of that switch comes out of the EBCM and goes to the BPMV but the pin number isn't defined in the schematic. You may be able to determine it when you have everything in front of you. If you measure this circuit through the BPMV you should see a low resistance (discussed previously).
However, you will be probably be better off following the diagnostic for your year car that I posted in the other thread.
Several of us are saying the same thing. You need to listen.
Bill
Old Dec 3, 2008 | 01:57 PM
lucky131969
Bill
Sorry Bill, I didn't realize there were numerous posts.
Old Dec 3, 2008 | 02:05 PM
lucky131969
No biggie, but now you have me curious. Does your 2002 wiring diagram look different than this?
http://www.flickr.com/photos/1545929...46747/sizes/l/
I don't see the connection from G101 to G102.
Old Dec 3, 2008 | 03:17 PM
byronhunter
I don't see the connection from G101 to G102.[/QUOTE]
Lucky, I caused this confusion, I looked at it wrong, sorry.
Old Dec 3, 2008 | 03:21 PM
lucky131969
Lucky, I caused this confusion, I looked at it wrong, sorry.[/QUOTE]
No sweat, I have the service manual for 97-05, I just wanted to make sure mine is accurate.
Old Dec 3, 2008 | 04:00 PM
tonycorvettes
thanks for that
Old Dec 3, 2008 | 04:13 PM
tonycorvettes
Default ok
fuse 5 is good,,and im getting a solid ground at f and g ,,,and 12 v at a at the harnes connector ,,,and i do see an open condition looking into the unit itself on f ,some people are telling me grnd c101 and some 103 ? all i know its the one by the pump on the left lise rail ,,,,,,,,,,,,,,,,,,what next please
Old Dec 3, 2008 | 04:20 PM
lucky131969
12 volts where? You should have 12 volts at pin A continuously, and 12 volts at pin B with the ignition "on"(engine not running).
Also, like Bill already stated, the specific pin for the 12 volt input is not identified on the schematic. If you can ascertain which pin that is by visual inspection, you can take a resistance reading through the motor.
Old Dec 3, 2008 | 04:24 PM
tonycorvettes
Default yes
that what i have 12 volts on a and 12v on b key on ,,give me something else
To c1242 abs code need help
Old Dec 3, 2008 | 04:26 PM
lucky131969
that what i hace volt on a and on b key on
read my additional comment to my last post....
Old Dec 3, 2008 | 04:30 PM
tonycorvettes
Default dont understand
explain what you want me to read,,looking into the internal connection?or are you asking me to find another 12v from the harness connector? should i do this? Using J 39200 DMM, measure resistance between BPMV internal connector terminal 8 and motor ground stud
Old Dec 3, 2008 | 04:37 PM
lucky131969
what is the resistance value of the grounds at F & G ?
