Wiring schematic help
Old Dec 5, 2008 | 02:23 PM
ROYZZO6's Avatar
ROYZZO6
Default Wiring schematic help
I'm looking for the wiring schematic for the l/f headlight (just the l/f low beam wont work, everything else is fine) yes, I checked the bulb LOL
Also I need a schematic for the interior wiring to the fold down mirrors, my light have never worked in those.
Thank you
Roy
2002 Z06
Old Dec 5, 2008 | 03:11 PM
lucky131969's Avatar
lucky131969
Thank you
Roy
2002 Z06
http://www.flickr.com/photos/1545929...43098/sizes/l/
http://www.flickr.com/photos/1545929...04329/sizes/l/
Old Dec 5, 2008 | 03:51 PM
ROYZZO6's Avatar
ROYZZO6
Thank you
Old Jan 26, 2009 | 08:19 PM
ROYZZO6's Avatar
ROYZZO6
OK, I'm finally getting around to working on this and I need some help. I really don't understand the schematic very well. Both of my interior fold down mirror lights don't work and my under hood light doesn't work. According to the schematic they are connected (if I'm reading it correctly) but I don't understand where to follow it to so I can check for power?
Any help would be great, thanks.
Old Jan 26, 2009 | 08:30 PM
byronhunter's Avatar
byronhunter
Check fuse #2 IP Fuse Block.
Also if it's bad underhood lamp and glove compt lamp will be out.
Old Jan 26, 2009 | 08:31 PM
ROYZZO6's Avatar
ROYZZO6
Oh and my rear view mirror lights don't work, so it does appear that these are all connected, and it looks like they all go to a relay, so where is it located?
Old Jan 26, 2009 | 08:35 PM
byronhunter
Relay #37 in IP Fuse block.
Old Jan 26, 2009 | 08:43 PM
ROYZZO6's Avatar
ROYZZO6
Is there only one fuse panel, the one next to the battery?
If so I checked the #2 fuse and it looked fine, but to be safe I switched it with other one and no change, I need to find my test light.
I'll check the relay now, thank you for your help.
Old Jan 26, 2009 | 08:47 PM
byronhunter
IP fuse block is under pass side toe board.
Old Jan 26, 2009 | 08:51 PM
ROYZZO6's Avatar
ROYZZO6
Ok, thank you, I'll go check those. Sorry for making this difficult.
Old Jan 26, 2009 | 09:00 PM
ROYZZO6's Avatar
ROYZZO6
Found the IP fuse box, the #2 fuse was blown, swapped it with a spare, still nothing. Moved onto the #37 relay, swapped it with a working one, nothing.
So my next guess would be to see if I have power at the fuse, i'll go try and find my test light, if anyone has any more ideas feel free. Thanks
Old Jan 26, 2009 | 09:19 PM
ROYZZO6's Avatar
ROYZZO6
Not sure what happened something weird, but I was waking away from the car and the under light just came on. All the lighting works perfectly now, 20 minutes after I replaced the fuse, who knows it must have just been a bad fuse all along.
Thank you byronhunter.
Old Jan 26, 2009 | 09:40 PM
byronhunter
That circuit is monitered by the BCM and times out after (I think) about 15 minutes. So it had timed out when you replaced the blown fuse-so no lights. Then you did something to wake up the BCM, then lights came on. That help?
BH
Old Jan 26, 2009 | 10:03 PM
lucky131969
BH
you put your right foot in, you put your right foot out, you put your right foot in...........
To Wiring schematic help
