gm10-aux trouble second try!
Old Dec 5, 2008 | 06:33 PM
bcartman2's Avatar
bcartman2
Default gm10-aux trouble second try!
I tried posting this in audio with no replies, can one of you help?
I tried this procedure and I still get an error, are there any other methods to try?
Trouble getting your stock head unit to recognize GM10-Aux?
Sometimes if you loose power to the radio (dead/disconnected battery), or unplug the GM10-Aux converter, your stock head unit may not want to go to or stay on "Disc 1 Track 1" like it should. After getting some advice from other forum members I put thogther this little procedure that has worked for me every time so far:
-unplug GM10-Aux from Cor-Har changer cable
-let it sit overnight (a few hours at least)
-with car still off, plug in GM10-Aux
-let it sit for at least 10 minutes
-turn on car & radio, select changer on radio
-if it works (Disc 1 Track 1) you're done
-if it doesn't work, leave car running but turn off radio
-unplug GM10-Aux, then reconnect it
-turn on radio, it should work
Old Dec 6, 2008 | 01:04 AM
Roc87's Avatar
Roc87
I have had all kinds of problems with my adapter. Even without the battery going dead, it'll lose connection with the gm10-aux. I usually just unplug the adapter at the cd-changer harness with the radio on, car running and then plug it back in. It sometimes takes a few tries, but it starts working again eventually. Sorry I can't be more help, just keep the connection in an easy area to get to and don't bother waiting overnight if it don't work the first try.
Old Dec 6, 2008 | 11:03 AM
bcartman2's Avatar
bcartman2
thanks, i will give it a try
Old Dec 6, 2008 | 03:02 PM
bcartman2's Avatar
bcartman2
thanks a bunch tried it with everything on, it worked first time
Old Dec 6, 2008 | 03:15 PM
Roc87's Avatar
Roc87
Glad to hear
To gm10-aux trouble second try!
