drain tank
Old Dec 7, 2008 | 02:41 PM
Blow Torch's Avatar
Blow Torch
Default drain tank
Does anyone have the tank draining instructions for the racetronix system. I have a new LPE pump to install, but I installed all of the racetronix harness and still have the jumper wire that came with it.
I just don't remember how I hooked it up to drain the tank before opening it
Old Dec 7, 2008 | 02:48 PM
lucky131969's Avatar
lucky131969
It's still actuated off the fuel pump relay, no?
Old Dec 7, 2008 | 03:59 PM
Blow Torch's Avatar
Blow Torch
I guess; But I would assume that you wouldn't want to switch on the car ignition, and not sure if the regular would let it pump or not. I know that the racetronix system actually included a wire and plug with jumper in order to drain the tank, which would seem like a waste if all you have to do is unhook the line and switch on the car
Old Dec 7, 2008 | 04:01 PM
lucky131969
That's not my point. Just turning on the ignition won't work, because the fuel pump only turns on for 2 seconds. Just jumper the fuel pump relay in the underhood electrical center, and it will run continuously.
Old Dec 8, 2008 | 04:48 AM
Racetronix's Avatar
Racetronix
Supporting Vendor
The power jumper plugs into the pump booster connector just after the relay. Hook the test clip up to the battery +.
Old Dec 8, 2008 | 07:41 AM
Blow Torch's Avatar
Blow Torch
Thanks guys
Old Dec 8, 2008 | 01:46 PM
lucky131969
Is the power jumper plug fused?
Old Dec 8, 2008 | 04:47 PM
Blow Torch's Avatar
Blow Torch
Yes; I took a look at it last night an it has an in line fuse.
Old Dec 8, 2008 | 04:51 PM
lucky131969
Sounds like you're good to go
Old Dec 9, 2008 | 03:54 AM
Racetronix's Avatar
Racetronix
Supporting Vendor
To drain tank
