Crank position and cam position sensor?
If only I had a LH sending unit, my fuel gauge would actually be functional. Oh well, at least I can drive my 174k mile car now and got to pass/waive at another C5 in the area.
Thanks to everyone here for helping me especially lucky for being so patient.
1. The pins in the underhood fusebox was repaired. I kept plugging and unplugging the fuel pump relay causing the pins to be recessed.
2. Around the LH fuel pump harness connector was frayed. Someone must have previously probed the heck out of the wires and caused them too short out. I did not notice this because I only looked at the connector it self and was getting voltage. Intermittent shorts was causing my fuel gauge to go crazy plus cut power to the fuel pump whenever it felt like it.
3. My dash lights were diming on and off very lightly, but i thought maybe this was a typical Chevrolet feature. They pulled my dash and soldered some contacts somewhere. This makes my turn signals 100% reliable now.
4. My LH axle seal is leaking a little, but will be fixed very soon.
In the next 4-6 months I will try and enjoy the car at least just cruising. When I can get more $$ I will get an ls7 clutch and rebuilt diff with some 3.90's. My fuel sending units were fine since voltage was being read with EFI live.
Thanks again to everybody here in the forums and ATLPF, i would get some pics up, but the car is dirty now and it needs some attention to the RH front fender.
