Rear Differential Help
Old Dec 8, 2008 | 06:08 PM
bschmergel's Avatar
bschmergel
Default Rear Differential Help
Hi Guys,
Turns out on my 2001 convertible 6 speed, that the rear diffential is bad. I have two questions...
1. Anyone have experience with RPM Transmission or Rockland Standard? I have reccomendations from both...
2. The car has a 3.42 now, should I swich to a 3.90?
Thanks Guys!!
Old Dec 8, 2008 | 06:26 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Originally Posted by bschmergel
Hi Guys,
Thanks Guys!!
RPM is the way to go. I have bought several units from them and have had no problems.
Don't know why you want a 3.90 unless you're a drag racer.
Old Dec 8, 2008 | 06:41 PM
vsocks1's Avatar
vsocks1
RPM is the way to go. A gear change will cost nothing when they are swapping diff's....depends on what your goals are as to the gear!
Old Dec 8, 2008 | 06:42 PM
bschmergel's Avatar
bschmergel
Thanks, the car is stock, thought the 3.90 would make it quicker. It costs the same amount.
Old Dec 8, 2008 | 06:43 PM
bschmergel's Avatar
bschmergel
I want quicker acceleration. For a stock car I assume I don't need the heavy duty version...correct?
Old Dec 8, 2008 | 06:51 PM
lucky131969's Avatar
lucky131969
All depends on how you drive it.
Old Dec 8, 2008 | 08:34 PM
vsocks1's Avatar
vsocks1
For stock horsepower they will probably say stage I - but for piece of mind I would go stage 2.
Old Dec 9, 2008 | 05:38 AM
vettenuts's Avatar
vettenuts
I would go 3.90, it makes 6th gear on the highway so much more useable. Also, while in there you might consider some upgrades.
Old Dec 9, 2008 | 01:46 PM
Ksths2's Avatar
Ksths2
what about the 4.10 with a 6 speed? anyone drag race and also drive on the highway with a 4.10? What kind of rpms?
Old Dec 9, 2008 | 01:51 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Go here to figure out.
http://xse.com/leres/bin/gearratio?t...mference=87.96
Old Dec 9, 2008 | 01:52 PM
Ksths2's Avatar
Ksths2
hmmm, cool link thanks AJG1915
Old Dec 9, 2008 | 01:54 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
No problem.
To Rear Differential Help
