My 98 suddenly stopped running. At first I suspected the fuel pump since there was no fuel in the rail. But after applying 12 volts directly to the pump I quickly ruled that out, ran fine. Next I checked all the fuses and relays in the fuse block. The fuse for the fuel pump was only out putting 7.5-8 volts the other two fuses right next to it also read 7.5-8 volts, all others were normal. Any ideas on where to go next?
I bet you a cold one that its hosed! I have a ignition switch repair post that explains how to repair and restore it. Thats a PRIME suspect for flukey lower than normal circuit voltages. Try rapidly turning your key on/off,on/off a few times and see if that changes symptoms.
You can also measure all the voltages at the fuses that are supplied by the ignition switch when it is in the HOT IN ON AND ACC position. You can also see if the pump runs in the CRANK position. Thats another dead give away of a bad switch!
Have you checked the state of your battery? You need a solid 12.6 vdc to get things to run. Battery connections at the battery and at the starter. If you can, pull the codes. The ignition switch may also be a source of issue.
Check the condition of the wires (in harness bundles) just below the battery (in stock location) Many times, battery acid leaks out of the posts, drips onto wire bundles, eats through wire insullation, etc. Hose those wires down with alot of water, see if the problem 'changes' in any way. If so, get to those wires. Good luck.
Good point on the battery leaking, and it is a common problem with C5's. Concerning the "hosing down with a lot of water", you do know what resides under the battery right?
2016 C2 of Year
2015 C3 of Year Finalist
Originally Posted by Bill Curlee
CHECK YOUR IGNITION SWITCH!
