Transfluid capacity???
Old Dec 14, 2008 | 09:44 PM
-Fidanza-'s Avatar
-Fidanza-
Default Transfluid capacity???
How many qts does the tranny hold?
Old Dec 14, 2008 | 09:51 PM
Alaskanpilot's Avatar
Alaskanpilot
St. Jude Donor '08-'09-'10
I don't know the exact number, but I do know it's recommended to buy 4 quarts for the fluid change... so I would guess between 3 and 4 quarts. But that's for a manual... what kind of tranny are we talking about?
Old Dec 14, 2008 | 11:52 PM
-Fidanza-'s Avatar
-Fidanza-
I though 8 sounded off, the lady at Carquest told me to get 8 qts! It's a manual
Old Dec 15, 2008 | 12:09 AM
lucky131969's Avatar
lucky131969
When in doubt, just read your owner's manual:
http://www.gmpartshouse.com/download...00corvette.pdf
Old Dec 15, 2008 | 12:42 AM
2L8ULUZ's Avatar
2L8ULUZ
I just changed the fluid in my 6 speed and I bought 4 quarts of mobil 1 synthetic dexron III ATF and used all but about 1/2 quart.
Old Dec 15, 2008 | 12:58 AM
-Fidanza-'s Avatar
-Fidanza-
Thanks, was it hard?
Old Dec 15, 2008 | 01:03 AM
lucky131969
If you have to ask, you had probably get a procedure from someone before attempting it.
Old Dec 15, 2008 | 01:48 AM
-Fidanza-'s Avatar
-Fidanza-
well compared to taking my whole rear diff out yesterday and swapping it w dte stg 3 and dropping my tunnel plate and all of that good stuff there's no way changing the fluid's gonna be hard haha
Old Dec 15, 2008 | 02:03 AM
lucky131969
If you can handle that, you're fine
Old Dec 15, 2008 | 08:42 AM
clemsondave's Avatar
clemsondave
I did mine last week. Piece of cake assuming you have one of those cheap pumps. Held about 3.5 qts. I used Royal Purple Synchro.
Old Dec 15, 2008 | 10:57 PM
2L8ULUZ's Avatar
2L8ULUZ
Not at all. If you have just even a basic mechanical knowledge you can perform this service. Just get it up in the air and remove the drain plug and let it drain good and then put the plug back in and remove the fill plug and install 3 1/2 quarts of fluid and you are good to go. It is really very easy.
Old Dec 16, 2008 | 12:52 AM
-Fidanza-'s Avatar
-Fidanza-
Thanks for all of the imput guys, I am changing it with Royal Purple Syncromax... I've been hearing nothing but good things about that stuff!
Old Dec 16, 2008 | 08:06 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Excellent choice!
To Transfluid capacity???
