Head stud question
Old Dec 15, 2008 | 01:11 AM
69dodgecharger's Avatar
69dodgecharger
Default Head stud question
Hey,
so this weekend I will be installing a ported FAST 90/90, AFR 205's and a G5X3. I was planning on using cometic head gaskets and maybe running ARP head studs. I was wondering if the head studs can be installed with the engine in the car? And with the studs in, can the heads be installed with the motor in the car. Just curious because I know that there are many motors that must be removed if you have using studs.
Old Dec 15, 2008 | 05:56 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Yes, you can install them with the engine in the car, and yes, there is plenty of room to slide the heads on and off with the studs in place.
Here's a pic of them installed before heads went on.
Old Dec 15, 2008 | 09:26 AM
vettenuts's Avatar
vettenuts
Yes, but I had to disconnect the header and O2 sensor at the X-pipe so I could drop them down low out of the way.
Old Dec 15, 2008 | 12:12 PM
69dodgecharger
cool thanks
To Head stud question
