COIL OVER PROBLEM FIXED
Old Jan 17, 2002 | 02:35 PM
vettethret's Avatar
vettethret
Default COIL OVER PROBLEM FIXED
Just a post to say the roblem is finally fixed.The coil overs from WCC are the same ones that breathless performance sells, the manufacturer is proshocks.The back end was extremley soft with the 300 lbs springs in the back so I went with 550 lb springs in the back and it fixed the problem.If you get these coilovers from Breathless or WCC MAKE SURE YOU GO HEAVIER IN THE BACK OR THE CAR WILL BE WAY TO SOFT.I have the car lowered and with the back end that soft I completely destroyed the inner fender well.Just wanted to thank seanr for his post and peter over at doug rippie for the expert knowledge.A very big thanks to craig over at WCC who replaced the fender well for free and did not charge me labor for Pro shocks mistakes.The car is now very solid and stiff, it feels like a race car.Thanks again Craig, seanr, and peter. :D :cheers:
Old Jan 17, 2002 | 02:40 PM
Austrian Vette's Avatar
Austrian Vette
Default Re: COIL OVER PROBLEM FIXED (vettethret)
Congrats on you fix vettethret!
Well done WCC!!
Michael
Old Jan 17, 2002 | 02:45 PM
vettethret's Avatar
vettethret
Default Re: COIL OVER PROBLEM FIXED (Austrian Vette)
Thank you :cheers:
Old Jan 17, 2002 | 03:00 PM
vette.se's Avatar
vette.se
Happy to hear you finaly got it right :cheers:
Old Jan 17, 2002 | 03:31 PM
Guest
Guest
Posts: n/a
Glad to hear that, i have bought the same set and kind og got worried when i read your post , what spring rate do you have in front ?
Old Jan 17, 2002 | 03:43 PM
vettethret's Avatar
vettethret
Default Re: COIL OVER PROBLEM FIXED (c5norway)
The spring rate in the front is 500lbs. The car is very stiff but not unbareable.You can look on the spring itself and see what it is rated at.There is a little aluminum tag on the spring to show what the rate is. Let me know if you have any other questions. :cheers:
Old Jan 17, 2002 | 04:27 PM
CliffB-99's Avatar
CliffB-99
Good news. Glad it worked out for ya!
:cheers: :smash: :chevy :flag
Old Jan 17, 2002 | 04:38 PM
MelloYellow's Avatar
MelloYellow
Default Re: COIL OVER PROBLEM FIXED (CliffB-99)
Congrats!
Old Jan 17, 2002 | 04:48 PM
cjones's Avatar
cjones
Default Re: COIL OVER PROBLEM FIXED (MelloYellow)
Was straight line traction improved with the coilover setup compared to the stock setup?
Old Jan 17, 2002 | 04:56 PM
vettethret's Avatar
vettethret
Default Re: COIL OVER PROBLEM FIXED (cjones)
I cant really tell about straight line performance.All I know is that when I take an on ramp and I'm cornering hard, it sucks all the breath out of me.With stiff springs I'm not sure how it would compare to the factory Z51.
Sorry I couldn't be more help!
Old Jan 17, 2002 | 08:12 PM
C54TIM's Avatar
C54TIM
Glade to hear all is well!
Now that's what I call good service, keeping in touch with the vendor/customer and the vendor solving the problem!
Very cool, can't wait to order mine! (If they'll let me LOL)
Tim
Old Jan 18, 2002 | 12:25 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
glad to hear that you worked everything out, and WCC sounds like they were proffesional about the situation.
Old Jan 18, 2002 | 01:40 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Peter your an :blueangel: from a real race place :cheers:
If it was me I would have been :lol:
Old Jan 18, 2002 | 07:04 PM
oceanaire's Avatar
oceanaire
I just looked at mine and they say 350 in the back. Doesn't feel soft at all. My fender well is fine so far!!
Old Jan 18, 2002 | 07:19 PM
vettethret's Avatar
vettethret
Default Re: COIL OVER PROBLEM FIXED (oceanaire)
Who is the manufacturer? My car is at 25 1/2" from center ground to top of well.I personally inspected the coil over as they removed it from the car.The spring was softer than a baby as@. Either they are different manufacturers we are talking about here or pro shock accidentally sent me a 350lb drag shock, which they said wasn't the case. Either way the set up was way wrong and is now fixed with a 550lb, doug rippie uses a 600lb for the back!
Old Jan 18, 2002 | 07:40 PM
oceanaire's Avatar
oceanaire
They're probably the same manufacturer as mine came from BPP. My car is about an inch higher than yours. You must really be sitting on the ground.
Whats the 350 lb drag shock?
Old Jan 18, 2002 | 08:02 PM
vettethret's Avatar
vettethret
They are the same manufacturer.My spring had a little aluminium tag around the coil that said 350.I cant figure out why mine were so soft. If you look on WCC web site you'll see theat they have softer springs for drag racing.My back tires are almost tucked.Trying to get ahold of a digital camera so I can post some pictures. :cheers:
Old Jan 18, 2002 | 08:09 PM
oceanaire's Avatar
oceanaire
Sounds like my springs. Maybe you got a hold of some defective ones. Who knows. Thanks, Eric
To COIL OVER PROBLEM FIXED
