Rearend Movement
Old Dec 16, 2008 | 09:22 AM
brasher801's Avatar
brasher801
Default Rearend Movement
Seems I have a little to much movement in the rear of my 2001 when on roads with beat out pavement or on groved roads. Its a little more than trolleying. (Trolleying?? not sure thats the way to spell it)
Old Dec 16, 2008 | 09:24 AM
brasher801's Avatar
brasher801
Default Tire removal and installation
I am having new tires put on my 2001 and I bought them from Tire Rack. Can someone tell me who can put these 40 and 45 tires on. My local dealer will not touch them.
Old Dec 16, 2008 | 10:26 AM
Warped Sol's Avatar
Warped Sol
Don't know about Bama, but Discount Tire will do it in Dallas, Texas. Won't even flinch.
Old Dec 16, 2008 | 10:46 AM
Thickraybans's Avatar
Thickraybans
Try here http://www.tirerack.com/installer/In...120+&x=14&y=11
Old Dec 16, 2008 | 02:46 PM
Bill Dearborn's Avatar
Bill Dearborn
If you are installing Goodyear Run Flats you may need to go to a Goodyear store that is certified to install them. My local Goodyear isn't qualified and I have to go to a different town or to the Chevy dealer to get them installed. Since there are not a lot of cars that use run flats there are not a lot of tire stores that buy the expensive machine required to install run flat tires.
Bill
Old Dec 16, 2008 | 03:08 PM
brasher801's Avatar
brasher801
Default F1 g3
Good year F1 G3 tires but not run flat. I finaly found one guy here in town that says no problem and even knew the tire sensors would need to be reset. He also suggested an alignment to make sure I get good life from the new skins. He seemed very knowledgeable.
Any more advice before I head off in the morning to hve him do it?
To Rearend Movement
