Charge System Fault
Old Dec 16, 2008 | 11:51 AM
Dudule's Avatar
Dudule
Default Charge System Fault
Ok guys, here is the latest issue I have on my 01 coupe.
Perhaps the freezing temps that we have currentlt where I live are part of the problem (average 34° F).
The last time I took the car, drove it for a few miles and stopped the engine I had this message on the DIC when turning the ignition ON (together with a rather weak gauge lighting). The engine cranked OK and the charge appeared good (13 V).
I don't know what the problem can be as my battery is one year old.
Thank's for your feedback on this issue guys.
Greg
Old Dec 16, 2008 | 01:04 PM
lucky131969's Avatar
lucky131969
Greg
codes please......
Old Dec 16, 2008 | 05:30 PM
Bluefire's Avatar
Bluefire
Greg
Check the Battery and starter connections (both ends of each). That is most likely the culprit.
Old Dec 16, 2008 | 05:39 PM
2003Torch's Avatar
2003Torch
Greg
13v from the gauge would indicate a low charging condition and not usually normal after just using the battery to start the engine. If this was measured with a voltmeter also low. Check connections as recommended already and verify grounds are secure.
Old Dec 16, 2008 | 06:16 PM
Bill Dearborn's Avatar
Bill Dearborn
I have been getting this for 5 years on my Z. The message shows up for a short period right after start up and then goes away. I may see it once every 30 or 40 starts. Nothing wrong with the car.
Bill
To Charge System Fault
