DIC problems
Old Dec 16, 2008 | 07:35 PM
Billysp's Avatar
Billysp
2nd Gear
Default DIC problems
Please Help. I have a 2004 vette with around 55000 miles on it. I keep getting all kinds of DIC warning lights. The codes are BO-RFA C2110,
28-TCS C1282 & C1278, 38-RTD No Comm. Also showing is Shocks inopritive, maximum speed 80 MPH, Service ride control and sevice vehicel soon. I took it to the dealer and they charge me alot to put it on their scanner, but couldn't really tell me what the problem was.
Old Dec 16, 2008 | 09:07 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Two things.. look at the battery connections and make sure they are tight and the battery is fully charged. If good, check for a possible shorting wire inside either of the doorjam accordian tubes. Using the search, you can easily find Bill Curlee's posts with pictures on this. The no comm bothers me... tells me that the RTD unit isn't talking to the rest of the units. I didn't have a 2004 rather a '99 and it didn't have that option, so no clue there but you might wish to PM Bill Curlee just in case.
Old Dec 16, 2008 | 10:02 PM
Billysp's Avatar
Billysp
2nd Gear
Thanks for the info from what I can see this may be a common problem with these cars.
Old Dec 17, 2008 | 02:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
2004?? Do you even have the F-45 or F-55 Selective Ride option? If you dont, you most likely either have a shorted serial data wire OR your BCM is WET! Check the BCM in the passengers foot well under the toe board. Feel the underlayment under the carpet for dampness. If the BCM gets wet or even damp, it will freak out and cause what your seeing. I would also look for bare wires on the door wiring harness by removing the accordion tubes.
BC
To DIC problems
