installing a x-pipe
Old Dec 17, 2008 | 01:11 PM
gillarockus's Avatar
gillarockus
Default installing a x-pipe
what needs to be done to install a x-pipe on a factory car?
i plan on keeping my stock manifolds and ti exhaust for now, im concerned with the cat removal, i see o2 sensors there, how do you remove these without setting ses lights?
thanks
Old Dec 17, 2008 | 03:29 PM
Last C5's Avatar
Last C5
thanks
You don't touch the 02 sensors if all you're doing is installing an X pipe.
Jack the car up, loosen cat backs, measure carefully, very carefully and use a chain cutter to remove the rear section of the mid pipe, then install the new X, bolt the cat back back up and you're good to go.
Old Dec 17, 2008 | 03:35 PM
lucky131969's Avatar
lucky131969
Reminds me of that old Zeppelin song......... "Communication Breakdown"
Old Dec 17, 2008 | 05:53 PM
Last C5's Avatar
Last C5
Is he asking a different question than the one I'm answering?? Wouldn't be the first time.
Old Dec 17, 2008 | 07:44 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
What type of x pipe are you talking about?
If you do not have headers you are not going to replace your cats with an x pipe.
you will replace the H pipe section that bolts to your mufflers with an cross over pipe "x pipe"
It will severely quiet your car.
To installing a x-pipe
