Normal Numbers
Old Dec 17, 2008 | 09:14 PM
versacestl's Avatar
versacestl
Default Normal Numbers
I was wondering what normal readings for oil / coolant temps are as well as a normal oil pressure number?
Secondly, my clutch spring snapped today, so i need to get a new one,
I am assuming i can get this at any chevy dealer... Are they pricey and it looks like a easy self install... Also with the spring not being there how is the clutch resume back to its normal position, i can engage it and it comes all the way back out... I thought this is what the spring was for...
Old Dec 18, 2008 | 08:16 AM
argonaut's Avatar
argonaut
At highway speed my numbers as reported by the DIC are approx: coolant 170-200; oil temp 200-210; oil pressure roughly 30+psi.
Old Dec 18, 2008 | 09:10 AM
versacestl's Avatar
versacestl
What are the possible causes of my oil pressure staying between 60-80.. The weather just got really frigid, so i didn't know if that was a reason? Before the climate changed it looked to stay around 40psi.
Old Dec 18, 2008 | 03:29 PM
versacestl's Avatar
versacestl
I read up about the spring, seems it won't cause any harm as though people remove them for personal preferences..
So what about my oil pressure being so high, is that normal with cold weather (25f and below)? Or is this something i should look into?
Old Dec 19, 2008 | 10:52 AM
versacestl's Avatar
versacestl
Anyone?
Old Dec 19, 2008 | 06:37 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
at 40 degreees f, my oil press is 53 cold, 42 hot 2001 coupe, all stock
Old Dec 19, 2008 | 06:50 PM
lucky131969's Avatar
lucky131969
Originally Posted by versacestl
Anyone?
what does the DIC display oil pressure at?
Old Dec 21, 2008 | 12:47 PM
dataporter's Avatar
dataporter
If it is like 129 or something like that, it could be the famous oil pressure sending unit is out of wack
Old Dec 21, 2008 | 03:52 PM
versacestl's Avatar
versacestl
The DIC has been displaying the numbers between 50-75 lately. sometimes 45
Old Dec 23, 2008 | 11:21 AM
versacestl's Avatar
versacestl
Could it be "out of wack" because of the frigid temps?
Old Dec 23, 2008 | 11:25 AM
C4B4the04's Avatar
C4B4the04
When the sensors die they read REALLY high values, and they can peg out the gauge from what I understand. I suppose it could be going bad....thats a heck of a job to tackle for a maybe. More likely its just thick cold oil.
What weight oil are you using? I know on my older cars when I had 10W40 there were some high readings when it got really frigid.
Cassidy
Old Dec 24, 2008 | 12:22 PM
versacestl's Avatar
versacestl
I think i used 10/5-W30..
Where is the oil reader at and what's it like for a fix replace if that is the problem.
To Normal Numbers
