No Competitive Mode?? TCS Discussion
Old Dec 25, 2008 | 05:57 PM
Bill Dearborn's Avatar
Bill Dearborn
Originally Posted by 00Corvette
Thanks though Bill cause I was wondering the same thing...I didn't think that the EBCM would be sending any type of "torque reduction" signal at a stand still.
Definitely PCM controlled.
Now...if it is PCM controlled, is there any way to update the file or something to the newer version???
DZ
That is basically the message in my posts. Either, the BCM or EBCM sends a signal to the PCM through the datalink. That is the only way the PCM would know what mode the EBCM is in. If the PCM can be inhibited from seeing that particular message frame on the data link the car will not reduce throttle when power braking.
Bill
Old Dec 25, 2008 | 07:00 PM
Jim Taylor's Avatar
Jim Taylor
I have held the traction control button down for much longer than 10 seconds on my 2000 A4, and I do not get a "Competitive Mode" message on the DIC. It seems that some cars have it and some don't -- at least pre-2001 cars.
Old Dec 25, 2008 | 07:11 PM
fdxpilot's Avatar
fdxpilot
As mentioned in numerous posts earlier in the thread, if you don't have the option JL4, Active Handling, you can't have "Competition Mode." As "Competition Mode" is Traction Control Off and Active Handling On, no Active Handling makes that tough.
Old Dec 26, 2008 | 01:09 AM
Bell's Avatar
Bell
Wow, there is alot of good healthy discussion going on here - we all learn from it - together.
I don't know which module is sensing what, all I know is...
1. To do a burnout, you have to have TC OFF or it's quite embarrassing (the computer bogs the engine down and makes you look like a rookie who doesn't know how to do a proper burnout).
2. Upon launching, you have to have TC OFF or if your tires spin even a little bit, the computer will bog the engine down and add several tenths to your ET (also embarrassing).
3. On my 02 coupe, I intentionally use Competitive Driving mode because a) TC must be OFF for the burnout, b) TC must be OFF for launch, and c) I want Active Handling ON to straighten the car out for me if it starts getting squirrelly (I'm not too proud to admit that my Corvette's computers are WAY faster than my reflexes).
Old Dec 27, 2008 | 12:36 PM
Drewstein's Avatar
Drewstein
I didn't say it didn't happen. I just said if it truly does what you are saying it has nothing to do with the ABS/TC/AH system. There is no way for the EBCM to do that. Torque management is a function of the PCM not the EBCM. In a traction control event the PCM sends a requested torque signal to the PCM and the PCM sends a return signal telling the EBCM that torque has been reduced. The EBCM can only request a torque reduction if the drivers foot is off the brake pedal and there is a difference between front and rear wheel speeds. Neither of those conditions exist when you are power braking.
Read a technical article on the way ABS/TC/AH work on the C5 and other cars and you will see what I mean.
Bill
What if you turned off torque management when you tuned your vette?
Old Dec 27, 2008 | 12:47 PM
RC45's Avatar
RC45
If you power brake, doesnt that imply that the front wheels are not turning (zero wheel speed) and the rear wheels are turning (wheel speed above zero), and that there is significant diffence between the speeds of the front a rear wheels... and unless the TC/AH/ABS/Torque Management/PCM/EBCM system was designed to take this situation into account it would "panic" and believe that there was a significant problem and it was time to get the rear wheels to slow down?
It would stand to reason that the condition described by the OP is quite possible and even probable if the entire system was not designed/programmed to detect the "power brake" situation. And even if the car checks for "brake pedal" position, a line lock would really throw a system that doesnt check the yaw sensors and accellerometers
Just a thought.
Perhaps these are the major programming and logic and condition checks that were put into AH II vs AH I.
Old Dec 27, 2008 | 02:20 PM
C5XTASY's Avatar
C5XTASY
Doesn't make any difference. Mine is turned off and I still can't powerbrake unless both Traction Control and Active Handling are turned off.
Ed
Old Dec 27, 2008 | 02:46 PM
RC45's Avatar
RC45
Ed
It sounds like the system does not like to see the back wheels moving that much faster than the front wheels. Interesting.
Old Dec 27, 2008 | 06:00 PM
C5XTASY's Avatar
C5XTASY
In Competitive Driving, when powerbraking, I'm standing hard on the brakes. I don't believe the back wheels are moving at all. It seems to be related to a particular rpm zone, i.e. 1200-1500 rpms. Power begins cycling down, at that point, and then back up, but never exceeds the point at which it began the cycling. When Active Handling is turned off, no problem.
Ed
Old Dec 27, 2008 | 11:34 PM
RC45's Avatar
RC45
Ed
Ok.. I was thinking perhaps just before you launched the car the semi-burnout state where the rear wheels spin a little as you throttle with brake still engaged,while the front wheels barely move was throwing the system off.
Old Feb 4, 2015 | 08:25 PM
Vette Dreemz's Avatar
Vette Dreemz
Default reply to Comp mode
Originally Posted by drew47000000
Okay so I was under the impression that Chevy added the comptetive mode TCS to 2001-up, but this past week I ran into a gentleman at the strip who had a 2000 like mine that had Comp. mode. He even showed me, he held the button down for 5-10 secs and the screen read "Competitve Mode." I thought this guy might have been mistaking about his year, and opened the door to read a mfgr date of 4/2000. So now im wondering if there's something wrong with my car because it only does TCS on/off. Any thoughts? Thanks!
andrew
I have a '99 and until my EBCM went south on my last year and my finding out that there is no replacement or repair except for a junk yard part and then only getting the same piece of junk for an exorbitant price (+/- $1700.00) which is unacceptable. Withthe EBCM fried, I have warning lights every time I start the car that read "Service ABS, Service Active Handling, and Service Traction Control". Till it went south, I could press the button on the console for 7 to 10 seconds and it went like hell. Now it just goes. So Sad.
Old Feb 11, 2015 | 09:16 AM
3boystoys's Avatar
3boystoys
Never heard of this before. The EBCM has no way of knowing what the driver is doing with the throttle. It gets all of its speed information from the wheel speed sensors. If somebody is powerbraking all 4 sensors are reading zero speed and the EBCM doesn't see a differential between front and rear wheel speeds so it will not request a reduction in torque. As far as the EBCM is concerned you can be sitting at a stop sign with your foot off the throttle or with the throttle buried and it will not know.
If this truly happens with an early JL4 car it hasn't got anything to do with the ABS/TC/AH subsystem.
Bill
The main engine computer knows what's happening and controls this I would guess. Brakes on should not allow more fuel, actually I just read Hyundai now builds all their cars with this feature, if you have your foot on the brake, no matter what you do to the gas pedal has no effect. Some study they quoted that most unintended acceleration was people with their foot on gas and brake at the same time.
