No Competitive Mode?? TCS Discussion
andrew
Bingo. We have a winner. You have to have Active Handling to get competition mode, which is TC off and AH on. Hence, no AH, no Comp Mode. So, a 98 with JL4 will have Comp Mode. As mentioned, the 2nd Gen AH, intoduced in 01 as standard, has a better activation. You don't have to be stopped.
Generation I Active Handling can only be engaged while the car is stopped...although you can begin the 5 second countdown while the car is moving, the car must be stopped at the point of timeout. So, you can hold the button down while coasting up to a light, for example, for approximately 4 seconds, but at that 5th second when it times out for Competitive Driving to engage, the car must be stopped or it will not go into Competitive Driving mode.
Generation II Active Handling can be engaged while the car is moving.
With Generation I, you cannot powerbrake with Active Handling engaged, either with Traction Control activated, or in Competitive Driving. The further you depress the accelerator, while attempting to powerbrake, the more the engine will downpower (torque management). In order to powerbrake, you will have to turn off both Traction Control and Active Handling.
This is not true with Generation II Active Handling. That system will allow you to powerbrake in Competitive Driving.
There are some other differences, also, such as Generation II Active Handling is also a little less intrusive than Generation I.
Generation II consists of different components and programming than Generation I. A Generation I car cannot be converted to a Generation II system (at least for anything near a reasonable price).
Maybe more than you wanted to know, but there it is.
Ed
Ed
Ed
If this truly happens with an early JL4 car it hasn't got anything to do with the ABS/TC/AH subsystem.
Bill
noticed any difference, although I am not a track guy, perhaps the car needs to be driven with an agreesive attitude for this option to be noticed?
Bill
After you try it in Competitive Driving, turn off both Traction Control and Active Handling, try it again, and then post back the results.
Ed
Ed
Read a technical article on the way ABS/TC/AH work on the C5 and other cars and you will see what I mean.
Bill
Bill
A 1998-2000 Corvette, with Generation I Active Handling, will not allow powerbraking in Competitive Driving mode (Traction Control off - Active Handling on). With Traction Control off, and, Active Handling off, you can powerbrake the car. The only difference here is that Active Handling is turned off.
Take a look at this thread:
http://forums.corvetteforum.com/c5-t...arded-but.html
Ed
Ed
Bill
Bill
You are an amazing guy, Bill. The whole point of this discussion began when you questioned whether what I said actually happened. It does happen and it happens only on 1998-2000 cars, with Active Handling. And the ONLY way to powerbrake one of these Generation I cars is to turn Active Handling off. So, if you can explain how it is not related to Generation I Active Handling, I would love to hear it. Othersise, does it really matter how it happens? The fact is it does happen.
Ed
Definitely PCM controlled.
Now...if it is PCM controlled, is there any way to update the file or something to the newer version???
DZ
My 2000 FRC has it.
