TB coolant bypass effects?
Old Dec 20, 2008 | 07:17 PM
mcgilles's Avatar
mcgilles
Default TB coolant bypass effects?
I was thinking about doing this mod because its inexpensive and some report a hp or two from it and every little bit helps.
I live in an area where its almost never below freezing, so I'm not too worried about it. but if I drove somewhere or moved somewhere that actually has a winter would this be a good mod to undo for the winter months? I know its designed to prevent the throttle plate from freezing, but how much of a risk is there of that happening really? I have a vararam, so maybe increased than stock in that case? just wondering if others that have done this that live in colder climates are concerned about it, or remove it for the cooler weather.
Old Dec 20, 2008 | 07:56 PM
lucky131969's Avatar
lucky131969
I'd leave it alone. The gain you'll realize(if any) will never be felt in the SOTP, and most likely could only be measured on a dyno.
Better off going with the performance hood seal....
Old Dec 20, 2008 | 08:05 PM
clif's Avatar
clif
St. Jude Donor '09-'10
From what I know, the water goes through the TB, to WARM to air! This helps it to combust better to help emissions. This is counter to what we do. we do COLD air intakes! I did my TB bypass a few months ago.
Old Dec 20, 2008 | 08:12 PM
lucky131969
Really?
http://www.flickr.com/photos/1545929...89324/sizes/l/
Old Dec 20, 2008 | 08:15 PM
vettekidc5's Avatar
vettekidc5
If the coolant prevented throttle body from opening like the link above states, then why does the LS2 have no coolant running through it?
its worth doing the bypass just incase you ever have to remove the intake it makes it much easier.
Old Dec 20, 2008 | 08:35 PM
lionelhutz's Avatar
lionelhutz
I just did mine. I had the TB off and it sucked to disconnect that short little hose. So, I bypassed it. Not really expecting any performance gains but then I don't drive the car when it's freezing so not really worried about it acting up.
Peter
Old Dec 20, 2008 | 08:37 PM
motogib1's Avatar
motogib1
Why bother, you will never feel the difference. Waste of time. If you want to do a cheap mod install a vararam.
Old Dec 20, 2008 | 08:46 PM
87SAM's Avatar
87SAM
It's one of those "feel good" mods we do because…..it feels good. The benefits are miniscule under normal circumstances. C4 guys were doing it and I did it also on my C4. I also remember hearing from C4 folks who did the mod in fairly cold climates stating no ill effects.
I do agree that it makes future TB removals easier.
Old Dec 20, 2008 | 08:50 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I doubt the mod has any benefit other then eliminating the PITA procedure of reconnecting the LH side hose to the TB...so just do it, and never fuss with that task again.
Old Dec 20, 2008 | 09:29 PM
TEXHAWK0's Avatar
TEXHAWK0
Don't waste your time messing with it. If you had to remove it for other reasons, it might not be worth reconnecting, but I would not spend any extra time just to be modifying something.
Old Dec 21, 2008 | 12:32 PM
tiojames's Avatar
tiojames
Spend the time doing something constructive for your car.
Old Dec 21, 2008 | 02:57 PM
dougbfresh's Avatar
dougbfresh
Maybe a TURBONATOR Or better yet a HOOD SEAL Where do you guys come up with this silly stuff anyway? Zip ties/hood seals/TB bypass-SILLY STUFF. You'd probably get better results just keeping your tires inflated correctly and changing plugs every 3 years.
Think I need to invent a pet rock that makes Corvettes faster, just Velcro it to the engine and you'll gain 5HP.
Old Dec 21, 2008 | 08:29 PM
NC99's Avatar
NC99
Not even worth opening the hood for.
Old Dec 22, 2008 | 06:20 PM
Sigfamily's Avatar
Sigfamily
What color will the rocks be available in???? Dude that is some funny stuff right there!!!
Old Dec 22, 2008 | 06:50 PM
The Wrench's Avatar
The Wrench
I proudly display my Lingenfelter decal, to honor a departed Corvette legend. But, I notice it scares the pants off the Ricers. That makes it worth about 50 HP easily.
DG
Old Dec 22, 2008 | 08:02 PM
Black04Z06's Avatar
Black04Z06
DG
That's funny!
Old Dec 22, 2008 | 10:15 PM
timemender's Avatar
timemender
Below is a link to some other high performance items akin to the throttle body coolant bypass discussed in this thread.
http://kalecoauto.com/index.php?main...fd4a74435015a0
To TB coolant bypass effects?
Old Dec 23, 2008 | 10:54 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I bypassed the TB coolant on my 85 Corvette and it made a significant difference in plenum temperature! The big aluminum heat sink stayed a LOT cooler with the elimination of the coolant.
Then I did the mod on my 98 and 02 Z. I too live in the FROZEN TRUNDRA (New England) and have NOT expierenced any issues. I do drive my car in very cold weather.
The Coolant was there to prevent Throttle Body Iceing in cars that operate in cold damp areas. Removing it wont hurt anything and like it was previously stated, may only make an insignificant difference in HP. The LS2 TB eliminated the coolant in that TB.
BC
Old Dec 24, 2008 | 09:15 AM
Twospeed's Avatar
Twospeed
I wasn't going to reply because there are too many scientists on the forum now. Most of these guys have never built a performance engine. Or raced one. Here goes. This is the idea, you do everything you can do to extract the last bit of power from the motor. Every little bit works together. 2 here 3 here it all begins to add up. That's why guys spend up to 1800= for a 90mm ported fast to get 11-25 horse out of it. Why because it is a great buy for the money? No because every little bit helps when you look at the over all total result. Simple in concept but most people just don't get it. Colder air is more dense than warmer air. The more air in, and the more air out = more power. Now just the by pass and the hood seal will not put you in the 11s at the track, but if you combine these with what ever else you can do, then the final out come will put a smile on your face
Old Dec 24, 2008 | 09:50 AM
dougbfresh's Avatar
dougbfresh
$1800 for TB-when a little shot of Nitrous can do the trick for 1/4 the price. You want cold air, shoot some Nitrous in the intake. Save the "Voodoo" tricks for the snake oil salesmen-still like the "Performance Pet Rock" though.
