Serpentine belt question
Old Dec 26, 2008 | 08:54 PM
FLORIDA's Avatar
FLORIDA
St. Jude Donor '07
I am available next Wednesday Dec 31 near the Orlando airport, exit 12 off 528, Goldenrod. You might have to order the Gaterback belts. You bring the belts and I will bring the tools. Steve 321-987-7741
Old Dec 27, 2008 | 11:53 AM
jngoldin's Avatar
jngoldin
I replaced my main serpentine belt in probably less than 10 minutes. Used a long breaker bar with a 15 mm socket to move the belt tensioner. I agree with other posters, it is really easy.
Old Dec 27, 2008 | 02:22 PM
TEXHAWK0's Avatar
TEXHAWK0
I just looked at my factory Z06 belts and it came with
6PK2030 and 4PK1073 belts.
Gatorback makes a 4060798 (6PK2025) and a 4060802 (6PK2035)
I think I would go with the belt that is slightly longer rather than shorter.
Same on the other belt.
Gatorbacks are 4040420 (4PK1065) and 4040425 (4PK1080).
So you can go 8mm under or 7mm over.
Note, the length is coded in the part number. ]
2030 is the length in mm, or about 79.9 inches.
1073 is about 1073/25.4 = 42.2 inches.
Old Dec 27, 2008 | 06:41 PM
lp2k's Avatar
lp2k
so tex, your saying i should go slightly larger? reason by any chance? thanks everyone
Old Dec 27, 2008 | 07:15 PM
TEXHAWK0's Avatar
TEXHAWK0
What I was pointing out is that the Gatorback belts do not come in the exact factory size, so you have to go slightly smaller or slightly larger.
What I have run into on other cars is that if you go smaller, you may not be able to get the belt on. Whereas if you go slightly larger, the belt tensioner will still be within working range.
In this case, you may be able to use the smaller belt. Either way, your are only talking about 5mm to 7mm, or .2 to .3 inches difference.
Old Jan 1, 2009 | 05:48 PM
Patman's Avatar
Patman
Your local mechanic may be able to do this easily.
I just had a local mechanic do mine, although the guy is also familiar with C5s since he's got a supercharged 2002 Z06! He only charged me $24 in labor to change the belts!
Old Jan 2, 2009 | 10:05 AM
cycleboy's Avatar
cycleboy
3rd Gear
Guys,
I just replaced both serpentine belts in my 98 C5 mid Dec. I was pulling out of the garage last night and noticed a whine coming from the engine compartment. On close inspection, I noticed the Crank Shaft pulley is out of allignment with the rest of the pulleys. I called the dealer and they said this is a known issue with the C5s and the new CS pulley is 279 plus tax. It looks to me that the main belt CS pulley has slid back about a quarter inch and the belt is riding on the front of the crank shaft pulley. Does anyone have any suggestions? I am mechanically inclined and have tools. Is this something a one man own garage mechanic can do alone? I do not want to give anymore money to the dealership.
Old Jan 2, 2009 | 10:22 AM
The Wrench's Avatar
The Wrench
Cycleboy, yes, this is a pretty common issue. Replacing the front pulley/balancer is not a trivial task; but many of us have done it in the garage with jackstands and the normal assortment of tools. You must pull the steering rack, etc, etc. Plan on 5-6 hours of fun for a novice.
Imagine what the dealer will want??????
By the time you get the pulley off, you are half way to a cam install (hint, hint). I would suggest you install an underdrive (smaller pulley). They are priced about $250 from aSD, Powerbond, SLP, etc.
Do a search here, tons of info and photos.
DG
Old Jan 11, 2009 | 05:44 PM
FLORIDA's Avatar
FLORIDA
St. Jude Donor '07
Lp2K Are you still interested in my help?
Old Jan 11, 2009 | 11:01 PM
iced98lx's Avatar
iced98lx
DG
I picked my powerbond 25% UD pulley and both belts up from SDParts(.com) for $220 for my cam install. if you have an M6 it's easier than an A4 but the A4 is still not that bad.
Old Mar 27, 2009 | 11:43 PM
AviatorVette's Avatar
AviatorVette
i dont get it why these fools charge so much its annoying. Max I would pay for this kinda job is $30. I am going to have to do it on my own tomorrow. Hopefully it goes smoothly.
Old Sep 27, 2011 | 01:33 AM
KeyoRacing's Avatar
KeyoRacing
anyone know some place thats not going to KILL ME with the price to have them put the belts on in or near Philadelphia?
Old Sep 28, 2011 | 06:43 AM
  #33
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
piece of cake
Old Sep 28, 2011 | 07:03 AM
  #34
dbaker's Avatar
dbaker
Installing headers on my 02Z this week.....replacing both belts at same time.
\db2
carolina
Old Sep 28, 2011 | 01:29 PM
  #35
cdkcorvette7's Avatar
cdkcorvette7
Do it yourself, all you need is one wrench and the new belts.
BTW, you should start your own thread in the future. This one is really old...
Old Jan 27, 2012 | 09:34 AM
  #36
KingTut's Avatar
KingTut
Default Belt info
There is a lot of good information that gets lost when you start a new thread - and some of the best answers might get lost.
But I strongly second the thought that this is a DIY project. I got quots of $170 with no-name belts. Went to O'Reilly and got:
Gates Micro-V AT K040420 & K060798 for $48.98 + tax They fit perfect.
Took maybe 15 minutes - it always takes longer the first time. The service manual says use a breaker bar and you think that you are going to have to pull/push really hard. Not the case - one hand was plenty of pressure. I took off the belt at the alternator pully first and put it back last. On the A/C used the small middle pully as the on/off point.
Note old belts were 11 years and 30K old - they looked brand new - they do not make belts like they used to - they are way better and last way longer. Anyway I feel like I am good for another 10Y30K easy. Also did all the hoses - replaced with the silicone set - another technology step up and just a better product for longer lasting safety.
Old Jan 27, 2012 | 01:15 PM
  #37
cdkcorvette7
Check out this link in the rules section: http://forums.corvetteforum.com/foru...s-or-more.html
FWIW; I find it easiest to slip the drive belt off of the large smooth water pump pulley and to slip it over that pulley last when installing the new one on the upper drive belt system.
To Serpentine belt question
Old Jan 27, 2012 | 08:32 PM
  #38
QCVette's Avatar
QCVette
Active Streak: 90 Days
I have to agree with the other posts that this is a DIY job. It is probably only 10 or 15 minutes if you have access to ramps or can get it in the air a little for the AC belt from the bottom.
I did mine when I changed the harmonic balancer. There is nothing complicated about changing the belt. It is just a standard tensioner. Use the wrench/breaker and move it to release tension and the belt pulls off. It goes on the same way.
Find the belts you want (a lot of people like the gatorbacks) and DIY. You will then know you have the good belts and save a bunch of money.
Good luck.
Old Jan 28, 2012 | 09:40 AM
  #39
KingTut's Avatar
KingTut
And found there was this:
This rule will not apply to technical discussions or to posts in threads where such posts have been made to update the threads with information deemed by moderators to be of benefit to Forum members.
Old Feb 11, 2012 | 12:56 AM
  #40
Ready Z06's Avatar
Ready Z06
Cruising
How hard is it to change the ac tensioner on a c5 ZO6
