Why is my A/C button/light blinking??
Old Dec 21, 2008 | 09:10 PM
David426's Avatar
David426
Default Why is my A/C button/light blinking??
I've always turrned on my a/c in the winter time every other week to circulate the system so seals and o-rings won't dry out, causing leaks.. Tonite I turned on the a/c and the yellow light on the button started blinking and shut off after 4 seconds.. Its 32 degrees out here.. Does that have something to do with this? 2002 z06.. Never had a problem on any other car i have owned.. Thanks for the help
Old Dec 21, 2008 | 09:27 PM
lucky131969's Avatar
lucky131969
Do you have an owners manual? The operation is explained within.....
http://www.gmpartshouse.com/download...00corvette.pdf
http://www.flickr.com/photos/1545929...42424/sizes/o/
Old Dec 21, 2008 | 09:44 PM
71vetteinva's Avatar
71vetteinva
Do you have automatic climate control?
Old Dec 21, 2008 | 10:05 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
A/C does not operate below 35*, if it did your compressor would be short-lived.
People in northern states often go 6+ months w/o it, and don't experience any seal problems.
Old Dec 21, 2008 | 10:08 PM
jrose7004's Avatar
jrose7004
I'll bet he does.
Old Dec 22, 2008 | 12:52 AM
PierEagle's Avatar
PierEagle
All you have to do is start the car, warm it up, turn on your front defrosters and the a/c compressor will automatically run. It's part of the defrost system.
Old Dec 22, 2008 | 03:04 AM
DeeGee's Avatar
DeeGee
Its working normally. At 32 degrees the ac is inhibited and the light flashes to let you know.
I guess its rare to get 32 degrees in TX
Old Dec 22, 2008 | 08:09 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
BINGO!!
Although I store my car in the winter, I like to start it 2-3 times during the season, just to circulate the fluids, and keep the valve springs from sitting too long in one position. I also run the defroster, so the a/c compressor circulates the oil througn the system.
Old Dec 22, 2008 | 11:30 AM
David426's Avatar
David426
Thanks for all the good info. I should have looked at my owners manual first..
i kind of figured it was a normal thing in cold temps.. I just wanted more/correct info... And yes.. It does not get this cold very often in Dallas Tx,, The CAI is working really well in these cold temps
Old Dec 22, 2008 | 12:37 PM
AverageVetteNut's Avatar
AverageVetteNut
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
Ok... so it's a normal thing ofr the heater to turn onthe AC with the defroster set?
I have tried to turn mine OFF ( AC button ) and it blinks and then stays on.
Thought there was something wrong.
Old Dec 22, 2008 | 12:58 PM
lucky131969
Old Dec 22, 2008 | 08:27 PM
Marcs c5's Avatar
Marcs c5
Old Dec 22, 2008 | 08:36 PM
Bill Dearborn's Avatar
Bill Dearborn
Originally Posted by leadfoot4
BINGO!!
If you don't drive it you shouldn't do this. It is very bad for the car. Idling does nothing but build moisture and acids inside the engine and exhaust and it doesn't get hot enough to cook it out. If you are going to start it take it out for a 30 mile drive there are plenty of winter days to do that. I just drove mine last week and will probably drive it again in January when I get back from rainy and cold Southern California.
Bill
Old Dec 22, 2008 | 09:33 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Bill
Gotta get her hot to the tips or let her sit! my $00.02
Old Dec 22, 2008 | 09:52 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Geeeeeez, read post #4 again, Tom is correct
people post what they 'feel' is right, not the 'correct' information
Fact or Speculation, it matters
Old Dec 22, 2008 | 10:44 PM
av8rdavid's Avatar
av8rdavid
Happened to me yesterday and today! LOL!
Old Dec 23, 2008 | 01:26 AM
PierEagle's Avatar
PierEagle
Read post #6 again. Even if people don't use their a/c for 6mos +, if they turn on the front defroster at anytime during that period, they are maintaining their seals.
To Why is my A/C button/light blinking??
Old Dec 23, 2008 | 07:54 AM
AverageVetteNut
Thanks Lucky
Old Dec 23, 2008 | 01:29 PM
leadfoot4's Avatar
leadfoot4
Bill
Bill, I appreciate your input, however there are generally not enough days here where the roads are BOTH dry and road salt free. (Plus, I take the liability and collision insurance off my cars for the winter) This practice is something I've done with a number of cars over the last 34 years, and so far, there have been no repercussions. As I mentioned, I personally do not like the engine sitting in a static position for 4 months....
Old Dec 23, 2008 | 04:06 PM
poolboy's Avatar
poolboy
So after you let it run next time, and after you let it cool off, take the oil fill cap off and see if there are condensation drops on the underside. I too hate to let mine sit, so I do take it out (in MN no less) - as long as the road is dry it will not matter that they have been salted - dry salt will not adhere to anything, and even if it did, it only takes a few minutes to hose it off.
