starter replacement
Old Dec 23, 2008 | 08:31 AM
Black76's Avatar
Black76
Default starter replacement
How hard is it to replace the starter i have a manual 99 the graound clearance is so low
Old Dec 23, 2008 | 09:58 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Not too tough.
You will need to get the car up on jackstands, and disconnect the bettery.
If you have stock exhaust manifolds, you will need to unbolt the cats/H-pipe from the manifold flanges, and lower it down to gain access to the starter. The exhaust manifold can stay in place.
If you have LT headers, the pass. side header will likely need to come out, or at least unbolted from head and slid up and out of the way.
Remove the thick (red) positive cable from the starter, along with the 2 other smaller wires (gray and rust colored) that also connect to that same post. Remove the purple wire from the solenoid post.
Then remove the 2 bolts holding the starter in place, and it drops right out.
Install is reverse of what you disassembled. A competant mechanic should be able to do this in an hour or two easy. With headers, a bit longer.
Old Dec 23, 2008 | 10:14 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Be careful when reinstalling the starter to the engine. Use the correct torque. People have been known to break the block improperly torquing the starter back in. Also make sure that the wireing on the solenoid is clean and tight once your done.
Bill
Old Dec 23, 2008 | 10:16 AM
Black76's Avatar
Black76
Tks for the replys im going to try and change the starter out myself i think the seliond went it wont turn over and i know the battery is good
Old Dec 24, 2008 | 01:28 PM
waddisme's Avatar
waddisme
Make sure you note which wires go where. It can get confusing. I took a picture of mine before I removed them. Good Luck.
Old Dec 24, 2008 | 05:27 PM
lucky131969's Avatar
lucky131969
Have you covered all the basics in troubleshooting this issue? That's a lot of work if you don't know without a reasonable doubt that the starter is the issue.
Old Dec 25, 2008 | 10:22 AM
Old Rotor Head's Avatar
Old Rotor Head
Do 1 last check before you start this. I'm having the no start issue on my '99 and after I checked everything I found out it was (is) the positive battery cable. I cut the boot off, cleaned it all up, reconnected it and off it went (goes). I returned the starter I bought and will change the cable soon.
To starter replacement
