Harmonic Balancer question
Old Dec 25, 2008 | 07:49 PM
stunter steve's Avatar
stunter steve
Default Harmonic Balancer question
Can anyone tell me how difficult it is to change the Harmonic Balancer? I just bought a 2000 C5 and noticed the H/B has a wobble....thanks.
Old Dec 25, 2008 | 08:17 PM
vettefamily's Avatar
vettefamily
It's not very difficult, but make sure you get a new bolt and don't use the old one.
Old Dec 25, 2008 | 08:32 PM
dougbfresh's Avatar
dougbfresh
I believe you need to remove the steering rack and many have not been able to remove the old bolt without a very strong impact.
Old Dec 25, 2008 | 08:46 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Hey just a tip you might as well go ahead and replace your ac belt tensioner and AC idler pulley while you have the rack out.
you will thank me later. You may also consider and underdrive pulley as a replacement instead of the stock piece.
TEXHAWK0's Avatar
TEXHAWK0
Could quickly turn into a nightmare if you do not get full thread engagement, and end up stripping threads of breaking off a bolt.
Old Dec 25, 2008 | 09:43 PM
stunter steve
Thanks for the help guys....it's great to have a place like this to get advice!!!
Old Dec 25, 2008 | 10:11 PM
VIPERBLUELX's Avatar
VIPERBLUELX
use or make a proper pulley installer, do NOT use a bolt to pull your balancer on
Old Dec 26, 2008 | 07:30 AM
vettenuts's Avatar
vettenuts
Its not a bad job but you need to have the correct tools otherwise it can turn into a disaster very quickly. As others have stated, follow the GM procedure and don't follow the methods of LS1howto.com or you could end up in the "stripped thread club". You can rent a removal tool from Autozone to get the old pulley off. You should replace the seal as well that is in the timing cover. For re-installation, make a tool like I did or one of your own design. If you have an automatic, then a tool to hold the flywheel will also be required.
These cars are actually very easy to work on with the right tools and taking the proper amount of time for the job.
To Harmonic Balancer question
