Vararam Power Duct install (Help!!!!)
Old Dec 31, 2008 | 11:34 PM
FASST LN's Avatar
FASST LN
I tried heating the airbridge up to 170 degrees and I cooled my MAF down to 20 degrees. They were still not even close to fitting.
No amount of grease/lube is going to change that either.
Old Jan 1, 2009 | 09:27 PM
kerryt1's Avatar
kerryt1
Mine went right together with no issue, and I have no problems closing the hood either.
I'm sorry some of you are having problems, I can't understand why our experiences were so different.
Old Jan 2, 2009 | 04:33 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
I installed mine with some creative engineering (partly to make it fit better and improve the seal and partly due to integrating into a stock air box (bottom) lid).
I can share with you that there WAS an issue with the smaller MAF bridges (78mm - 97 - 2000), i.e. the molds were slightly off. This was corrected and new units shipped to vendors (about 2 weeks ago now). I have not heard (nor did the main technical resource I spoke to at Vararam before buying my bridge) of any issues with the 01+ (85mm).
I questioned the local tech extensively about fit, finish, choice of plastic / composition, etc. before purchasing.
After my creative engineering / Lowes parts sourcing, the bridge fits as well as the stock unit, does not even touch the hood liner at any point, much less rub or keep the hood from closing.
There are a few areas of improvement (I wish I had gone into mechanical engineering over IT sometimes); the bridge needs to be about an inch shorter on the MAF end (as you can see in the pics the MAF is sitting right on top of the TB opening, as mine did when I completed the install - there for a moment I almost considered trimming the plastic end of the MAF (I went with an 85Mmm MAF), but felt it might disturb the laminar flow on the end of the MAF, throwing off the calibration). In addition, they should have molded in the angle to align the MAF end with the TB end - similar to the way the Callaway adapter is designed (they had that part of their design correct - too bad the plastic they chose was too brittle - mine failed at about 5K miles, leaving me with an air leak before the MAF - needless to say I returned it to Callaway for a refund).
I don't know why the Vararam folks insist on all of this "interference fit" non-sense - same thing they did with the MAF to Vararam intake deal - of course when I had a Vararam on my car I trimmed the intake back a bit to allow the placement of a proper rubber coupler. On this bridge, same concept (interference fit), however better executed, although on my install (knowing the MAF would really never need to be separated from the bridge, even for cleaning) I ran a small bead of RTV around the edge of the MAF before inserting, filling in ANY small gaps the would / could arrive between the bridge opening and the MAF body (yes I understand about RTV + 02's = problem, no RTV / silicone entered the intake tract at all).
The plastic they chose for this bridge is "the right stuff" - not the hard / brittle stuff they are using for the intakes. IF Vararam would make the 2B's (call it a 3B I guess?) out of this bridge material, not only would they have a return customer (I loved the idea / design but hated the execution), but it would alleviate the concerns about cracking as well and I am sure it would help with the fit and finish.
All told this new bridge is a great idea - moving the MAF closer to the TB is a good move, and according to my logging it is flowing more air (higher MAP values) as well.
Again, with a little work on the install, it is a good piece and represents a good value.
On the OP's question / issue - it really does sound like you either a; recvd. one of those "defective", first run 97 - 2000 model units where the dimensions were off a bit (call Vararam and I am sure they will take care of you ASAP), or b; you are trying to install an 01+ MAF on an 97 - 2000 bridge.
Good luck.
Old Jan 7, 2009 | 03:53 PM
Jims Z06's Avatar
Jims Z06
Hey Guys..........
Recieved my "New" power duct from Patrick at Vararam yesterday. Took it out the box and immediately new that it would work. It was a different configuration than the first one I was sent.
The MAF slid right in with a little persuasion and everything lined up great! It was just a matter of selecting the right length couplers fore and aft to get the duct to sit down on the radiator support like the stock air box. No slamming the hood....no interference....no whistling! Can't wait for nicer weather to try it out and install some longtube headers.
Patrick at Vararam was very helpful.Thanks Pat!
Old Jan 7, 2009 | 05:04 PM
FASST LN's Avatar
FASST LN
Congrats Jim, I'm glad to hear there is a probable solution in place. My difficulty now is getting up with Vararam. I keep calling their tech line but the message box is full and by the time they call me back, I've left work (around 7:00 pm).
I'm certain they'll get me straightened out once we can talk on the phone. I've heard good things about these guys.
For reference:
I ordered the 97-00 airbridge but I'm running an '01+ MAF and a LS2 TB.
Old Jan 7, 2009 | 09:23 PM
VaraRam Industries's Avatar
VaraRam Industries
Supporting Vendor
St. Jude Donor '07-'11-'12
The power duct installation described here is limited to early 97-2000 model cars. (smaller air meter)
What we are seeing is some of these cars have either an updated MAF or after-market MAF and the owner was not aware of this, because he/she is the 2n-3rd owner etc...
We have also found some "TWEAKS" GM performed during there production cycle (97-99 models) that alters the motors location in some cars, but, not all.
We have now made adjustments to these early model ducts to give more room for "fit" in this area if needed.
We will be updating our website to ask the customer to check the the MAF to make sure it has not been changed to a newer unit or in some cases a modified factory unit with the high flow MAF ends etc.. before ordering.
No matter the configuration or combination ,we can always customize a duct here in our factory for you if needed, at no additional cost.
We offer this to insure the same seamless installation as we have for the later 01-04 cars (which use a bigger MAF)
We also do this for different motor/manifold & supercharger combinations you may be running on your vehicle.
We always appreciate our customers feedback
VR Tech
Old Jan 8, 2009 | 10:49 AM
FASST LN's Avatar
FASST LN
Just as expected, Patrick and the gang got me all straightened out.
My hat's off to them for superior customer service.
Thanks a lot guys!
Old Jul 21, 2009 | 05:33 PM
newcastle3's Avatar
newcastle3
St. Jude Donor '10
Default I know this is old, but these pics are the same as my problem
What did you do to correct this issue? I do not want to modify the radiator support.
Originally Posted by thezman
i still have a problem with my power duct there are two one is for 97 to2000 the other is for 2001 to 2004 ==here is my post http://http://forums.corvetteforum.c...post1568188395
DONT SLAM YOUR HOOD==Also your hood will not shut as it did originaly, you will have to SLAM IT HARD to get both sides to latch properly.
Old Jul 21, 2009 | 06:17 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Don't modify anything. What year car do you have? Some came with different motor mounts and VR is aware of this. They will special make you one to fit if this is the case. Contact them.
Old Jul 21, 2009 | 08:13 PM
Trpblk04's Avatar
Trpblk04
Originally Posted by vsocks1
You could also try putting the MAF in the freezer and then heating the Power Duct!
This works.
Old Jul 21, 2009 | 08:23 PM
JW Motorsports
Banned Scam/Spammer
The couplers need to be used also. I'm not going back and reading the whole thread, but Newcastle I hope you used the couplers.
Old Jul 22, 2009 | 10:14 AM
FASST LN's Avatar
FASST LN
I guess all of the little size variations in the engine bay make this product very difficult to line-up. I know mine isn't quite right either.
Must be why GM uses the accordion airbridge, to allow for mobility and adjustments...not to mention when the engine torques over when it's under load.
Definitely use the rubber couplers and the metal band clamps.
Old Jul 22, 2009 | 10:56 AM
  #33
mcgilles's Avatar
mcgilles
gotta get one of these!
Old Jul 22, 2009 | 01:47 PM
  #34
waddisme's Avatar
waddisme
Mine will be here Friday. Hope it is not this hard to install! BTW, they are having a nice sale incl Powerduct.
Old Jul 22, 2009 | 02:33 PM
  #35
newcastle3's Avatar
newcastle3
St. Jude Donor '10
I haven't modified anything yet, I have a 99 FRC. The MAF is in the duct, that is not the problem, the problem is like in the pics. The duct will not line up with the throttle body, it's almost like the engine is sitting too low in the engine bay.
I will try again to contact them.
UPDATE:
I just talked to Vararam and it looks like the duct will have to be modified, they are making one for me and I should have it by next week. This is obviously a common problem and if any one else has this problem my advice is to contact them before you modify anything.
I will update once I get and fit the new piece.
Old Aug 10, 2009 | 04:50 PM
  #36
MDR1970's Avatar
MDR1970
UPDATE:
I ran into the same problem with my 98 when i tried to install last night. The guys at Vararam were great in answering my questions. They instructed me to remove a 1\2" off the front of the duct where the MAF goes. This allows it to move closer to the TB thus allowing it to drop down 3/4". Should fix my problem.
Old Aug 10, 2009 | 10:59 PM
  #37
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Reading this thread I had to chuckle....before this duct came out...I modded a Halltech airbridge to the vararam intake god what a PITA lots o cutting and shaving I went back to the stock airbridge, even using the accordian part...no notice in loss of power or anything.
Old Jun 18, 2010 | 03:39 PM
  #38
Corvette Don's Avatar
Corvette Don
Anyone have any HP increase numbers using this Duct? I kinda do not like the idea of having the MAF directly in front of the TB.
Old Jun 18, 2010 | 08:59 PM
  #39
Nick1's Avatar
Nick1
On my '04 I had no problems, but I used the stock air duct. I also found it handy to re-use the flexible "accordian" mounted at the throttle body. This allows for "play" when opening it up for cleaning.
My maf is at the far end of the stock air bridge. All fits well and works well.
