'98 Shifting Problems
I think that I am fully depressing the clutch everytime it happens but have never changed the hydraulic fluid since new (now with 56,000 miles). Discussions with other Corvette people have suggested an ATF fluid change which didn't improve the situation a couple of years ago. Speculation that my late '98 had some inferior parts before Borg Warner was replaced by Tremec can't be determined without a transmission inspection/rebuild. Worn synchros could also be a factor but was not confirmed by a test drive by a Corvette mechanic. My C-5 Forum research hasn't identified a similar problem so this may not be a common complaint. Therefore, I'm hoping that some one might recognize these symptons and be abe to give me some direction to follow. Would a specific synthetic ATF help this particular transmission model? Are there any "magic" additives available? Any suggestions would be greatly appreciated!
Yes, changing from dino ATF to synthetic ATF made a significant difference for my 98 and 02 ZO6.
Jack up the back of the car. Put the trans in first gear with the clutch depressed. See if the rear tires spin and if they do how much force are they spinning with?
With the clutch depressed, they should not spin. NOTE!!! They might move a little if the trans is very cold but,,,,if the tranny oil is warm,,,when the clutch is depressed, it should not transmit any rotation to the wheels.
If you have a lot of rotation and there rotating with a LOT of force, your clutch isnt fully disengeging and that will make shifting difficult and wear out your synchros.
BC
Bill Curlee is right on with his explanation.
BTW, GM changed to carbon blocker rings in 2001, so those years and later can use any synthetic fluid.
AMSOIL ATF (product code ATFQT)
AMSOIL Torque-Drive Synthetic Transmission Fluid (product code ATD1G)
Although I have been using the ATF in my 02 Z06 track car for years and my CTS-V daily driver for about 6k miles now, I've recently learned that the ATD is more shear stable (actually is totally shear stable as it has no viscosity modifiers) and is thus my current recommendation for the C5 manual tranny. The ATF is very shear stable, much more so than the vast majority of Dexron III fluids on the market and has worked well for me in both of my cars, but given the demands our tranny places on the fluid, I think the ATD is the better of two good choices.
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
I told you he would set you straight on the good stuff!
marcussmith28 I agree that the synchros/blocker rings are probably not as good as they should BUT, changing the old nasty fluid or just up grading the dino ATF to the right synethic fluid will usually cure the problem and allow you to not have to rebuild the tranny for a long time.
IF, you continue to drive it the way it is, you will cause synchro and blocker damage much worse than it already is and then you will need a rebuild.
BTW, you get water in your fluids over time. One reason plus those fluids don't live forever. Not as they're designed to work anyway.
So I'm hoping that this is a long-term solution to my long-term problem. There may still be underlying synchros issues but this new fluid seems to have overcome the shifting problems for now...or at least has bought me more time. The last fluid change was 30,000 miles ago using standard GM ATF and it had a foul smell when drained. That would seem to prove the need for better synthetic fluids like the AMSOIL recommended. I don't think that I had a clutch problem but changing the fluid at 59,000 miles was a good idea anyway.
Thanks again for all the input and suggestions. Hopefully, this will help others with similar shifting problems.
