C5 Sway Bar Installation Question
Old Dec 28, 2008 | 08:24 AM
VET4JDC's Avatar
VET4JDC
Default C5 Sway Bar Installation Question
I am about to install C6 Z51 sway bars on my 2000 coupe and have two questions:
Does anyone know the correct torque settings for the bolts and nuts on the bushing brackets? (I've heard they should be around 75 ft/lbs)
Should you lubricate the inside of the bushings prior to installing on the sway bars? If so, with what type of lubricant?
Sorry...that was three questions.
Old Dec 28, 2008 | 08:41 AM
vettenuts's Avatar
vettenuts
I'm looking at installing these as well so report back your impressions.
Here are the torque values from my 2002 service manual. I used some white lithium grease on mine and it quieted it right down. It was noisy prior to me lubricating the insulators. Not sure how compatible the lithium grease is with the insulators though.
Front sway bar insulator brackets: 43 lb-ft
Front sway bar link nuts: 53 lb-ft
Rear sway bar insulator bracket bolt: 49 lb-ft
Rear sway bar insulator bracket nut: 70 lb-ft
Rear sway bar link nuts: 53 lb-ft
Old Dec 28, 2008 | 11:25 PM
napacruzerc5's Avatar
napacruzerc5
Sorry for jumping in but: can you remove old bar and install new by just working on front or back end at a time up on rhino ramps? Or does the whole car have to be up in the air with the wheels/suspension unloaded?
Old Dec 28, 2008 | 11:30 PM
convertz's Avatar
convertz
As long as the front or back end it lifted evenly you can do it. I did mine one end at a time, just have to make sure the wheels are either loaded or unloaded evenly so the end links line right up
Old Dec 31, 2008 | 09:14 AM
VET4JDC's Avatar
VET4JDC
Default Update
I did the sway bar installation yesterday. Everything went pretty smooth and it only took less than two hours from putting the car on ramps to test driving around the neighborhood.
I placed the front on two custom ramps that I made for changing my own oil. Then I lifted the back about 5" and rested the rear on some wood blocks. Weight distribution was probably close to that on the ground.
Install went great and the C6 Z51 bars bolted right on with no problems.
Torqued the bolts to spec as noted in the post above. Tossed those little weenie stock sway bars in the garbage and I'm ready to roll.
Old Dec 31, 2008 | 09:48 AM
ecoman's Avatar
ecoman
Your gonna love them
Old Feb 12, 2009 | 11:37 PM
RBMECH123's Avatar
RBMECH123
How do you know the amount of torque you turn?? I hve never known that. Plus , why do you have to lift the car ifyoure going to rest it on wooden blocks?
Old Feb 12, 2009 | 11:43 PM
JEEP/C5's Avatar
JEEP/C5
Uh - use a torque wrench. I prefer a digital one.
The car is to low to get under so you have to lift it.
Are these question are are you being funny?
Old Feb 12, 2009 | 11:53 PM
JEEP/C5's Avatar
JEEP/C5
I used a white lithium grease the first time I did my sway bars but a year or so later they started to creak so i purchased some poly bushing grease and that did the trick. Poly grease is extremely sticky and will not melt away like lithium did (lithium oozed out and made a sticky mess).
Old Feb 13, 2009 | 05:30 AM
vettenuts's Avatar
vettenuts
Where did you get the poly grease?
Old Feb 13, 2009 | 06:46 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
As far as LUBE goes use a SILICONE spray and you'll be set! Do not use oil or WD-40 for this can deteriate the rubber.
Thanks,Matt
Old Feb 13, 2009 | 09:45 AM
jovette's Avatar
jovette
Use the sticky elephant snot It's made for this purpose. Believe you can get it at auto parts stores across the country. I think I got mine @ auto zone.
Old Feb 13, 2009 | 04:07 PM
ALVETTE00's Avatar
ALVETTE00
I'm willing to bet you'll be seeking out every windy road now!
The stockers are so light, I think they're hollow!
LOL
Old Feb 16, 2009 | 08:15 AM
JEEP/C5's Avatar
JEEP/C5
It was included with the poly bushings I purchased at Ecklers (or was it Corvette Central). Auto zone and O reilly's should carrier it too.
Old Feb 16, 2009 | 08:27 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
The product called "Super Lube" is also good for poly sway bar bushings...
Old Feb 16, 2009 | 01:12 PM
vettegator005's Avatar
vettegator005
well how are the new sways treating you?
Old Feb 16, 2009 | 06:28 PM
JEEP/C5's Avatar
JEEP/C5
Great, one of the best mods I have done. Do yourself a favor and purchase the poly bushing - front and rear (most some with the proper lube too) and the aluminum end links and you will be squeak free and it will handle much better.
To C5 Sway Bar Installation Question
Old Feb 16, 2009 | 07:06 PM
bcseitz's Avatar
bcseitz
Yes I agree.
I've tried white lithium, Mobil 1 syn. grease (pink stuff), Silicone die-electric grease and they all dry out quickly and the car starts riding like it has no suspension at all.
I used the poly bushing grease that came with the poly bushings that I purchased from Ecklers and that's still holding up. And yes, that stuff is sticky. Not easy to wipe off your fingers and tools afterwards!
If anyone knows where to buy poly bushing silicone grease please post it up!
Old Feb 16, 2009 | 07:26 PM
leadfoot4's Avatar
leadfoot4
Originally Posted by bcseitz
....I used the poly bushing grease that came with the poly bushings that I purchased from Ecklers and that's still holding up. And yes, that stuff is sticky. Not easy to wipe off your fingers and tools afterwards!
If you find that the "Super Lube", that I highly recommend, isn't up to the job, Energy Suspension sells a "gorilla snot" lube. I say "gorilla snot", because it sticks like slime, to everything, and is quite difficult to get off your hands when finished. It DOES lube the bushings quite well.
I don't know the ES part number off hand, but it's available in a 2-3 oz. container for about $4-5 from ES dealers.
Old Feb 17, 2009 | 10:30 AM
bcseitz's Avatar
bcseitz
I found this stuff at Energy Suspension. Here's a link if interested.....
http://www.energysuspensionparts.com...p?prod=9.11104
