Rear Differential Help ASAP..
Old Dec 28, 2008 | 10:59 PM
vetterman1980's Avatar
vetterman1980
Default Rear Differential Help ASAP..
Just got my 2000 torn down today after breaking another HD 300mm output shaft, third one now I believe. Anyway, When I dissassembled the clutch pack on the broken side (long shaft drivers side) I discovered that the clutch pack preload spring was cracked, Is this a common problem, will the dealer have a new one in stock do you think or should i go aftermarket? Thanks in advance for any help.
Old Dec 29, 2008 | 07:10 AM
vsocks1's Avatar
vsocks1
Call RPM Transmissions. I believe they use HD Springs in their built diffs.
Old Dec 29, 2008 | 08:12 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
check out the plates themselves, they seem to always crack
I doubt dealer has item
To Rear Differential Help ASAP..
