When did you change your gas filter?
Old Jan 2, 2009 | 07:34 AM
vsocks1's Avatar
vsocks1
Originally Posted by LoneStarFRC
1. Yes. In the tank (left side as I recall)
2. Yes.
In the tank filter applies to '04. Two tanks applies to '97-'04.
Didn't the fuel system change happen mid '03?
Old Jan 2, 2009 | 08:40 AM
LoneStarFRC's Avatar
LoneStarFRC
Possibly. Seems like I recall someone mentioning that before. One thing's for sure though and that is that all the '04s are FFS systems.
Old Jan 2, 2009 | 08:42 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I'm big on preventive maintenance. I changed it when the car was 4 years old...even though it had only about 10,000 miles on it at the time.
Old Jan 2, 2009 | 08:45 AM
LoneStarFRC
I hear ya. Me too. I'd MUCH rather perform PM than CM any day.
Old Jan 2, 2009 | 09:31 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I have 30k miles on the original fuel filter. No plans to replace it for a long time.
Old Jan 2, 2009 | 12:56 PM
jbauch357's Avatar
jbauch357
I do it every 20k miles or so. In the past I've had issues with bad/clogged filters that were restricting my fuel delivery enough to rob power as low as 5k RPM.
Old Jan 2, 2009 | 03:14 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Default hmmm
hmmmm I keep forgetting...gonna have to put a sticky note up in the garage this spring....got almost 78,000 on my 02 now and don't think its every been changed.
Old Jan 2, 2009 | 04:14 PM
jrprich's Avatar
jrprich
Changed mine at 40k seems a reasonable life for a fuel filter
Old Jan 2, 2009 | 04:25 PM
GREENJOE's Avatar
GREENJOE
I have an '01 vert. I've posted about a gasoline smell when I allow the gas pump to shut it's self off. Could the gas smell be the result of a leaking fuel filter ? Is the filter and the cost to replace it expensive ?
Old Jan 2, 2009 | 06:21 PM
mike10626's Avatar
mike10626
Let's see 90,000 not yet.
Old Jan 2, 2009 | 06:39 PM
vetterlatethannever's Avatar
vetterlatethannever
Changed mine at 95k when adding a blower. Very clogged, won't wait that long again.
Old Jan 2, 2009 | 09:03 PM
C5Natie's Avatar
C5Natie
I have no leaks but wondered about changing it just for safety pm. are there any DIY links or something? Can I do this at home?
Old Jan 2, 2009 | 09:17 PM
  #33
briann510's Avatar
briann510
The FFS fuel system started with VIN number ending in 35114929, built on November 22, 2002 for 03's and have no external filter as well as 04's.
Old Jan 2, 2009 | 09:56 PM
  #34
Mr.TT's Avatar
Mr.TT
St. Jude Donor '10, '15-'16
I've been wanting to know if my '03 had an external filter or not. Thanks for the info.
Old Jan 3, 2009 | 11:00 AM
  #35
comecorrect's Avatar
comecorrect
I changed mine at 44K when I installed the blower. I have a 03 with the external filter. Very to do.
MIKE
Old Jan 3, 2009 | 08:32 PM
  #36
briann510's Avatar
briann510
MIKE
Ah one of the lucky Oct/early Nov 2002 builds for an 03 model!
Old Jan 3, 2009 | 11:05 PM
  #37
bighank's Avatar
bighank
Default Mine leaked like a sieve nylon retainer on line disintegrated
One of the very few "leakers" I've heard of. Curious. Was yours a case of an o-ring issue, a cracked/broken line or a loose fitting?
I changed mine about 65000 miles when it leaked all over the left muffler and tailpipe. One of the 2 nylon retainers on the line going into the filter disintegrated. It took me about 2 hours and that included removing the 2 bolts from the left muffler, sliding it aside (don't have to remove it just unbolt it), then took over a half hour to release the disintegrated fastner from the filter without damaging the fuel line.
Replace BOTH nylon retainers or you will be sorry later. New filter came with both retainers.
BIGHANK
