Thanks for that schematic, that helps a ton. I'll be stopping by radio shack today and picking up another DMM. I got into robotics a couple months ago and it must've gotten lost in the pile of stuff in my workshop.
I did check all the obvious stuff, but it was to no avail. Also, where'd you get that schematic from?
I found this post on another forum and the problems sound like exactly what I'm having:
Mine does exactly that. Doesn't turn over, doesn't click, doesn't do anything when I go from 'on' to 'start'. Let the key out of 'start' and back to just 'on' and everything is back to normal.
That schematic is directly from the 2000 C5 service manual. I have all the C5 service manuals.
Like I said, I would verify all inputs to the TDR. That exact scenario explained is also what a bad clutch switch will do as well. With the new relay installed, can you jumper the red and purple wire and get the car to start?
I'll need to find and order those manuals.
I'll try and check if I can do that with the new relay when I get home (I'm at work now). I was able to jumper those two wires with the old relay and the starter kicked in (that's why I thought it was the relay). The engine didn't turn over, but the starter did crank. I also didn't leave it on for too long because I didn't want to damage anything.
So you are saying that the starter engaged but the motor didn't turn over (rotate)?? That is a significantly bigger problem than just a no start condition.
Nono.. sorry, I'm not communicating right. It only did that when I jumped the two wires. I didn't hold them long enough to see if it would turn over because I was concerned that it'd mess something up.
Oh, ok.....You're not going to mess anything up, unless you try that with the car in gear.....
Ok I jumped the two wires again and it fired right up. I took it for a little cruise around the neighborhood so I could recharge the battery some more. I also pulled it back into my garage so it's not sitting outside. When I went to start it back up it did the same thing as before.
When my girl gets here I'll have her press the clutch pedal and I'll check the voltages then. Thanks for all the help so far!
Ok I checked the voltage at the pins. Red had +12 (just used that to make sure the DMM worked). Yellow had nothing to start. Pushed the clutch in, still 0. Turned the key to IGN and still 0.
I then went and bypassed the clutch switch by jumping from one prong to the other. Yellow had nothing to start. Pushed clutch in, 0. Turned the key to IGN and still 0.
Checked red and it was still 12 (to make sure DMM was still functioning).
Any ideas? :/
Please make sure the car is in neutral for the following:
You will only get 12 volts through the clutch pedal switch when the igniton is turned to the "start" positon. So, you need to have your DMM connected to C2 on the TDR connector (yellow wire from the clutch pedal switch) , then depress the the clutch pedal, and turn the ignition to start. If you can have someone assist you, you could feel the TDR to see if it clicks, and/or check for 12 volts at A2(purple wire of the TDR) which would tell you the relay is closing.
That's exactly what I did and I got 0. I'll redo it again later tonight to make sure I didn't do it wrong along the way.
If that's the case, and you have jumpered the clutch switch(at the clutch switch) and still get 0 volts at C2 of the TDR, the the problem is upstream. Make sure minifuse #14 is good in the passenger footwell. If it is, I would check continuity between the load side of minifuse #14 socket and C2 (yellow) on the TDR. You should read an "open" when the clutch pedal is up, and close to 0 ohms when depressed. I would depress the pedal numerous times to make sure the switch is not funky.
I jumpered the clutchswitch again and checked the mf itself and just the socket. 0. Does the clutch switch provide a ground or actual power to that socket? If it's power, is there a fuse upstream of that? Maybe I blew that fuse?
I checked for a connection between mf14 and the yellow cable and there is one there. The actual TDR itself isn't clicking when I turn the key though.
I'm trying to be as detailed as possible in my posts, but it doesn't sound like you're following. I'll PM you my number.
I have a set of '98 manuals if you want to borrow for schematics. Will they work for him being '98 model Lucky?
He has the correct schematic ( post #4 ), and I provided him an additional schematic ( post #19 ). Thanks for the offer. Nice someone local willing to help a brother
Ok.. I did what we spoke about and I got the responses you were saying. When the clutch was out it was 'open' and then it changed when the clutch was in.
So going by what I've done so far, all that's left is the ignition switch? Is there anyway to check if it's the key at all, or is that something that would've had to be done before the car went bad?
Here's the diagram highlighting what we've covered soo far:
We know the ciruit is good between the load side of fuse 14 and C2 of the TDR with the clutch pedal depressed, yet 12 volts is not present when trying to start the car. Since fuse 14 is good, that means the issue is upstream from the line side of the fuse socket to the ignition switch. You can do one final check if you want for 12 volts, with the key in start, at the line side of fuse 14. If probably won't be there, so you'll be investigating the ignition switch. Bill Curlee has a well documented procedure for the ignition switch. It can be found at the top of the tech section > Sticky: Important electrical information...go directly to post #559.
Cleaned the ignition switch tonight. There were some dark connectors that looked burned, so I did everything Bill said. Still won't start though :/
I'm going to go through tomorrow morning and verify all the connections again. I have off from work, so I'll be spending the whole long weekend trying to figure this out.
If you've got burned connections, about all you can do is gently file them down enough to expose the metal. But, if they are burned too far away, it won't do any good. All you can do then is buy a new switch.
