clock spring
Old Jan 3, 2009 | 06:34 PM
kid81's Avatar
kid81
Default clock spring
after doing searches, i found little instructions on replacing the clock spring on a 98. Does anyone have detailed instructions or pics of the job. thanks,
Old Jan 3, 2009 | 06:58 PM
lucky131969's Avatar
lucky131969
what instructions did you find? ....provide a link please..
Old Jan 3, 2009 | 07:16 PM
kid81's Avatar
kid81
the info was in a search. I said to unplug a couple plugs, unscrew 4 screws, use a hook puller to pull the wheel, etc. One said the procedure was in the manual. Written manual instructions would be great or pics...
Old Jan 3, 2009 | 08:44 PM
lucky131969
Right.......good luck with that.....
Old Jan 3, 2009 | 09:05 PM
2KFRC5's Avatar
2KFRC5
OK, clue me in. What's a Clock Spring that a '98 has?
Old Jan 4, 2009 | 12:24 AM
87SAM's Avatar
87SAM
I’m guessing it’s a convertible thing.
Folding Top Clock Spring Replacement
Removal Procedure
1. Open the folding top stowage lid.
2. Position the top with the number one bow and the number five bow up.
3. Grasp the clock spring with vice grips or pliers and remove the spring end from the roof link pin.
4. Remove the nut.
5. Remove the clock spring and pin.
Installation Procedure
1. Install the flat washer, bushing, and gripper washer to the clock spring pin.
2. Install the clock spring with pin to the arm.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
3. Install the nut. Tighten the clock spring nut to 3.5 N·m (30 lb in).
4. Grasp the end of the clock spring with vice grips or pliers.
5. Wind the clock spring and insert the end of the spring into the roof link pin.
Old Jan 4, 2009 | 12:31 AM
2KFRC5's Avatar
2KFRC5
That sounds perfectly reasonable to me. Learned something new today.
Retracted.
Old Jan 4, 2009 | 12:53 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I think it's over the muffler bearing right next to the blinker fluid reservoir
Old Jan 4, 2009 | 01:09 AM
87SAM's Avatar
87SAM
Well yeah, you're a coupe guy
Old Jan 4, 2009 | 07:56 PM
kid81's Avatar
kid81
OK . its the spring that has to work with the airbag and can be broken if the wheel is turned to far.
Old Jan 5, 2009 | 10:46 AM
87SAM's Avatar
87SAM
Wow, are you are talking about the Steering Wheel Inflator Module Coil? If so Lucky was right when he said “Right.......good luck with that..... ”. You really need a service manual. There’s danger in there and somewhat involved.
Old Jan 5, 2009 | 01:39 PM
Skinny Kid's Avatar
Skinny Kid
PM sent
Old Jan 6, 2009 | 08:55 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
1. remove the drivers side airbag.
2. remove the steering wheel.
3. pull the clockspring off the column and unplug it.
4. reverse the procedure to reassemble.
It's not difficult or dangerous but you do need the right tools to pull the steering wheel and I highly recommend a service manual.
To clock spring
