removing front seal without cover
Old Jan 6, 2009 | 03:36 PM
titus40's Avatar
titus40
Default removing front seal without cover
Im installing a powebond pulley and thought it might be a good idea to replace the front seal as the car has 70k miles. Anyways, it looks like i have to remove the water pump to get to the timing cover then take out the old front seal and put new one on. Is it possible to remove the old seal and put a new one on without removing the timing cover? Any help would be appreciated. Thanks
Old Jan 6, 2009 | 04:05 PM
vettenuts's Avatar
vettenuts
Yes. The ideal setup would be a two finger seal puller, not the one you pry with. The new one will install with your fingers.
Old Jan 6, 2009 | 04:53 PM
titus40's Avatar
titus40
So if need be I can yank the old one out with just about anything since I wont be reusing it and then I just push the new one in place? nothing more to it then that?
Old Jan 6, 2009 | 06:23 PM
vettenuts's Avatar
vettenuts
You should rent a tool (Autozone) and remove carefully. The cover is thin and the OD of the seal is a sealing surface as well so if you scratch the aluminum you will have a problem.
Old Jan 6, 2009 | 06:57 PM
titus40's Avatar
titus40
I went to the local autozone and they didn't have one for rent nor for sale. I'm going to need to get one cause man its on there good.
Might as well get a meziere if im going to take the pump off,lol.
To removing front seal without cover
