Coolant Change Woes
Old Jan 6, 2009 | 11:29 PM
Munch's Avatar
Munch
St. Jude Donor '10
Default Coolant Change Woes
I am going to put a set of braided hoses on my coupe and after reading the service manual and doing numerous searches on this forum I am a bit concerned about replacing the coolant. Am I going to have to do the whole rev the car up - let it cool down - add coolant and repeat as necessary thing as if I flushed the whole system? The coolant has maybe 5k miles on it.
I am also concerned about getting air in the system (now that I have read all the coolant posts).
Also, is there any reason I can't just use the 50/50 dex-cool?
Hope someone can put my concerns to rest. Thanks
Old Jan 6, 2009 | 11:46 PM
00Corvette's Avatar
00Corvette
If you want to be safe, just use the 50/50 dexcool and swap the hoses.
Don't worry about air bubbles, just start the car up and let it run for a minute til the T-stat opens(ish) then top off and all air bubbles should be gone.
Good luck!
DZ
Old Jan 7, 2009 | 12:35 AM
lucky131969's Avatar
lucky131969
If you have a service manual, you can put your own concerns to rest. Just the fact that you have that manual, and have the ability to read, gives you more knowledge the 50% of the guys on the forum. Follow the procedure and you will be fine, or you can follow someone's half *** advice on the fourm.....and struggle.
Use your manual and go for it
Old Jan 7, 2009 | 01:22 AM
bdiddo's Avatar
bdiddo
half *** advise...hmm. I have taken many tips from the forum and certainly would not call it half ***. Quite the opposite! In fact it saved my proverbial *** a few times.
Old Jan 7, 2009 | 02:14 AM
lucky131969
Originally Posted by 8VETTE7
We have to ASSume that this pertains to your advice as well.
Who cares what you or "we" think. If you want to dispute my advising the OP to follow his service manual......go right ahead....
Old Jan 7, 2009 | 03:26 AM
dieseldave56's Avatar
dieseldave56
Default Humor
I read your comments and was taken back. You obviously forgot to say 'joke'. We forget that tones and inflections can not always be abstracted from the written word , thus the posters actual meaning or thought is misconstrued.
Been in the auto business , seems like forever and this particular forum has surpisingly good advice a large % of the time. And then you can not argue advice of going to the service manuals for accurate information.
Old Jan 7, 2009 | 05:39 AM
vettenuts's Avatar
vettenuts
I have done coolant many times. I found that raising the front of the car results in no air pockets.
I mix my own 50/50 so I can control the water suppy. The biggest issue I have had is removing the two hoses on the side of the water pump. They make a mess and dump right onto the A/C compressor and belt. I found that I can make a channel out of aluminum foil a few layers thick placing one end under the passenger side of the pump and the hoses and direct the coolant that comes out over the front of the aluminum saddle and then into a large tub (another reason for raising the car is you can get a good catch basin under it).
Old Jan 7, 2009 | 09:48 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
[QUOTE=vettenuts;1568460252]I have done coolant many times. I found that raising the front of the car results in no air pockets.
I mix my own 50/50 so I can control the water suppy.[/QUOTE
Using only distilled or de-ionized water in the 50/50 mix is also my own personal preference.
I addition to raising the front end, I've found that leaving the surge tank cap LOOSE helps to dispel any trapped air during the initial warmup
and burping process described in the shop manual.
Old Jan 7, 2009 | 12:25 PM
Munch's Avatar
Munch
St. Jude Donor '10
Great tip, Thanks!
I guess I'll just follow my manual like a good boy, should be good experience.
Old Jan 7, 2009 | 02:28 PM
ALLEGRO's Avatar
ALLEGRO
As mentioned earlier, change the coolant, fill to the full line, start car and allow t-stat to be open, rev up 2K rpm's a few times. Then shut off car, allow to "burp" and then refill to full line.
It might take a day or so to get ALL the air out, but you will be very close the first time.
Good Luck with the coolant and hose change.
Old Jan 7, 2009 | 07:37 PM
Bill Dearborn's Avatar
Bill Dearborn
Great tip, Thanks!
I advise people to mix their own coolant as there is a couple of quarts of coolant that you can never get out of the block. I flush several times to make sure the left over is just water and then I add the coolant and more water and adjust the mixture by using a hydrometer.
Bill
To Coolant Change Woes
