a/c blinks and turns off
Old Jan 8, 2009 | 03:53 AM
szach13's Avatar
szach13
Default a/c blinks and turns off
i have a dual climate control and the when you push the a/c button it justs blinks and turns off.it don't matter what the temp is out it could be 90 or 10 outside is there a senor or something how do i fix this
Old Jan 8, 2009 | 07:35 AM
LO PHAT's Avatar
LO PHAT
In most cases this would be an idication of your A/C system needing a recharge. The freon also acts like a lubricant for the compressor, so your car's system will protect itself by not turning on if the A/C system is low. You may have a leak (fast or slow), so have it checked out professionally.
LO PHAT
Old Jan 8, 2009 | 07:45 AM
jngoldin's Avatar
jngoldin
Check the trouble codes. Are any set? The same symptom can also be caused by poor electrical connections or shorts. My A/C acted like that as a result of poor insulation of the Serial Data bus in the doors, although, in that case, you would most likely see a host of other trouble codes as well.
To a/c blinks and turns off
