Why no D-port headers?
Old Jan 20, 2002 | 12:18 AM
LT1GMC's Avatar
LT1GMC
Default Why no D-port headers?
Since C5 headers have left the price range of Hooker and Hedman and moved up to the exotic $800-$1600 range, why do none I've seen come with D-port flanges, which in my opinion should perform better since they would match the port? Is there a technical reason?
Old Jan 20, 2002 | 12:41 AM
Lawdogg's Avatar
Lawdogg
Active Streak: 90 Days
Default Re: Why no D-port headers? (LT1GMC)
I've been told by two different header designers of C5 headers that port matching is not important and may, if fact, be counterproductive to max. exhaust gas scaveging.
Old Jan 20, 2002 | 02:56 AM
Nate@CorvetteGarage's Avatar
Nate@CorvetteGarage
Supporting Vendor
Cruise-In I Veteran
St. Jude Contributor '04
Default Re: Why no D-port headers? (Rippied Z06)
I was told the same thing. Testing was done on d-port headers, and there were no gains...
Nate
Old Jan 20, 2002 | 02:51 PM
Steve Row's Avatar
Steve Row
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Why no D-port headers? (Nate@xtreme)
If this is so, then why did Chevy build the heads with "D" ports??
Something does not make sense.
Old Jan 20, 2002 | 03:10 PM
kewlbrz's Avatar
kewlbrz
Its actually a good thing to have a little larger pipe at the connect point to the head port. With a d-port head you get that using a round pipe. This helps cacel out high energy reflection waves from going into the chamber.
To Why no D-port headers?
