Cam Install: Jackstands Style - 56k warning
Idle under The hood:
Idle Behind (my favorite, I think)
And A rev to about 3500:
Starting two days ago Dvandentop (bless his soul, coming down from C6z to help a brother out) and myself are putting a new camshaft into my 98.
Prepped and ready:
Dvandentop workin his *** off:
New springs vs. Old springs:
Side one Done:
I made myself mildly useful and got the front cradle ready to drop
With the cradle dropped a little heat goes a long way:
Me goofin off:
Dvandentop is not amused:
woot.
Front cover came off last night too, we stopped there for the evening. We would have made it further but we didn't realize with the A4 we'd have to block the flywheel. We quick searched and read that we had to drop the starter, cats etc and did that to discover we'd have to take the manifold off to get the starter out..
so instead we poppeed the seal off the back of the bellhousing and crammed a screw driver in there while breaking the crank bolt loose.
So far so good! Today/tomorrow new cam in, meiling oil pump on 25% ud pulley and button it up!
The only thing I think we created extra work on so far was when we dropped the cats to the catback piping to try to get the starter down.
A4 people: to get the crank bolt out, just take the rubber plug on the bellhousing out and wedge a screwdriver/steel bar in to stop the flywheel. much easier, just as effective.
other parts list:
Nmotion timing set
10% increase melling oil pump
Powerbond 25% under-drive pulley
Patriot Xtreme .660 springs
Comp 7.400 pushrods
Would u please also mention which method did u use to change valve springs bcos i dont want air compressor and wanna do a TDC method. Post some more pics and i was interested in davendtop's silver Z06 when he sold 2 yrs ago that was badarse too.
headers question: I'll do headers later, I'm actually quite interested in what kind of gains you can get cam only (stock heads stock intake) and yes i know i can get much more with headers and an intake. That's the plan, right after I find out how much you gain cam only. It's a bit of a science experiment.
why didn't I buy the whole EG package? I am using all brand new components and with the cam have spent ~1000-1200 (not keeping 100% track, but could if needed). the whole EG package is a great deal but I managed to get a couple killer deals on some things that made it turn out in my favor on $$ end of things and ended up with a couple 'upgrades' to their package (Nmotion timing set, for example).
As for the springs, they took a bit longer because of the perimeter bolt heads, but we got them. We used the air compressor fitting in the spark plug hole and a spring compressor bar, along with a hacked up smaller one for the hard to get to/end ones. in the middle of the passenger side it took 5 min to to get spring off and new one on. The end ones took more trial and error, obviously.
Hopefully finishing up this afternoon and I'll have a first fire video on tonight. Of course delays are inevitable so who knows, it snowed 2 inches over night so there's no rush
WAY too much work compared to moving the rack!Why on earth did you remove the starter?
and again: glad you find it easier to move the rack, this didn't seem to impeed our progress that much but I'm sure glad you saved yourself the 20 min it took us to drop it and informed everyone of it, I'm sure everyone will now know the easier smarter way, which is what this forum is all about.
