I put a Hurst in my 01Z last night and it shifts great but I get quite a bit of road noise and air noise. I think it's due to the fact that the rubber plate the bolts over the base of the shifter doesn't seal against the shifter like the stock one did. Is there any good solution to this?
make yourself a new gasket out of some white polyethylene foam packing film... The type of material that wraps around and insulates new electronic components.
Mine never had any noise that other people talk about.
I guess some people are just too sensitive..
A heavy, tight fitting ****, would probably help. I have always had the Hurst ball.
Take out the demon pin and wrap the threads with teflon tape. I did this to mine when I went back to the stock shift **** and ALL road noise subsided. You'll be able to freely twist the **** around if you want to but it stays put quite well actually.
