NOS "NOSzle" System.
Old Jan 20, 2002 | 02:15 AM
paladine's Avatar
paladine
Default NOS "NOSzle" System.
Has anyone used the NOS NOSzle system? I run a 100 dry shot right now, and I'm curious if this system would be a good compromise between a wet and a dry system.
http://www.nosnitrous.com/HiOctn/Pro...OS/NOSzle.html
Old Jan 20, 2002 | 06:19 AM
C5Cemo's Avatar
C5Cemo
Default Re: NOS "NOSzle" System. (paladine)
I'm awaiting someone's real world results with this system myself. It looks real promising :D
I would consider this kit to be a compromise of dry vs. wet in only one way. It was designed to alleviate the worries that come from running raw fuel via. a normal wet kit through a dry manifold like ours.
It really is a sophisticated wet system with a superior direct port distribution design over the normal wet kit. This kit is gonna be a lot harder to setup, though...and maintain. I can only imagine how difficult finding a leak is gonna be...
Old Jan 20, 2002 | 06:24 AM
LovintheC5's Avatar
LovintheC5
Default Re: NOS "NOSzle" System. (C5Cemo)
I would think it would be easier to setup, you just click them in before the injectors. I talked to MTI about this, and they havent tried it yet, and its expensive...somewhere around 1500 for a basic kit without install. Does not include heater, rpm switch, or bottle opener. Looks like it would work well, they wondered whether it would hurt your performance when off the gas, since it doesnt have the typical injector sprayer on the end.
Daren
To NOS "NOSzle" System.
