how hard are superchargers on the engine?
Even if I did have a professional install, I was always bothered by the extra stress on the engine/drivetrain. Do engines with superchargers do well long-term. Let's say 100,000+miles with regular driving (very few racetrack visits).
Also, what does it do to daily driving and gas mileage. BTW, I was eyeballing the breathless performance supercharger:
Part# 500-100 Procharger Supercharger System $5,999.00
My car is completely stock.
[Modified by rbridges, 9:17 AM 1/20/2002]
I have just installed ATI Procharger on my car, I have not driven it yet.
It is no doubth about it will stress your engine and drivetrain more, but in the the end it is entire up to your self how you drive the car.
Her is a Quote from ATI Faq:
That is a very subjective question, as the manner in which an automobile is driven directly affects engine life. Assuming a properly tuned system, proper oil change and engine maintenance, and similar driving, supercharging generally will not shorten the life of an engine, just as is the case with OEM turbocharging (with proper cooldown for turbochargers. A cooldown period after driving is not necessary with supercharging). This is especially true of centrifugal supercharging, which generates boost in line with engine rpm, unlike roots and twin screw blowers, whose low rpm boost can place additional strain on the engine and drive train.
Superchargers can be used with automatic or manual transmissions and will not increase transmission wear under normal driving. When racing, however, the additional torque provided by supercharging will place additional load on the transmission, especially when increased traction is present, such as with slicks. This impact is minimized when the boost increases with engine rpm, as is the case with centrifugal supercharging and turbocharging.
Richard
[Modified by eikeland, 4:26 PM 1/20/2002]
This shouldn't cause a problem in wet weather since we wouldn't leave the stop light at 2500 RPM's.
If there is no boost until 2500 rpms then the average MPG on the highway shouldn't change very much either. Unless you cruise in 4th gear, that is. What do you think?
When you do not have your foot hard on it, gas mileage and drive ability seems about the same as stock... of course in my case going to a stroker, cam etc. on the C5 changes the gas mileage from stock, but not dramatically, if driven carefully. Of course this has nothing to do with the blower.
The computers these days are wonderful for keeping the car running smooth under normal driving conditions even if you have a built up motor and/ or a blower installation.
So basically I would personally not worry about the gas mileage and drive ability question. In fact I have seen blower installations on trucks and cars that have actually improved gas mileage 1 mpg or more, probably because proper tuning went along with the installation. Some of these cars have 80K miles on them and more.
I am really not a fan of putting a high boost (7lbs is high boost) blower on a stock engine. What I would really focus on for the C5 is:
Is your harmonic balancer keywayed so it will not spin under the high horsepower increase of the stock engine?
Do you have an 8 Rib pulley /belt system to avoid belt slippage and horse power loss.
Are you running no more the 10:1 compression? Any more could lead to disaster on a stock engine in the long run (that is what you are referring to in your post.. the long run).
Think about the bottom end of the engine. Think Lunati! Kicking out 490 RWHP (such as the ATI kit seems to do) is really hammering your stock bottom end.
Do you have an 8 Rib pulley /belt system to avoid belt slippage and horse power loss?
Did you properly modify your fuel delivery system to avoid fuel pressure loss and detonation?
And MOST importantly was the tuning on the installation done by an experienced computer chip tuner like Ron Zimmerman or Steve Cole. There are other factors to consider but these are some of the more important.
Mell
Mell
and I do NOT intend to start any discussion what is best for a SC Engine.
The rules is simple: If you want to be sure it will hold, then you follow Mel's example, and prepare your bottom but it will cost you more. The old saying is you get what you pay for.
But I have read about many SC solutions (especaly at LS1.COM and LS1TECH.COM) and it a few guys there who has runned a long time with 10PSI on stock bottom LS1 and raced it regulary, it is a gamble but it seams like many of them holds together.
I talked with many well known tuners and most of them recomended me use my low mile stock engine for the ATI.
ATI also clames to have the coolest air in the marked, and cooler air defently do not hurt the engine more.
PS! ATI has a 5-PSI 490 Shaft HP Package as well.
Anyway my way to look at it was i.e LPE (I figgured can blow 2-3 engines for LPE's prices). LPE offer state of the art LS1 package solution, I do not think anyone argue about that. But I also knew I needed Brakes, Clutch, better Cooling, tires, rimes, etc. So I did go with ATI and had budget left for other needed mods.
oh well since no one had done this so far...well some had to do it.
I guess after a while I will know how it went, I will not do much racing so expect mine to hold together for a while.
I have no idea if this make sense for anyone other the my self.... :crazy:
/Richard
[Modified by eikeland, 7:43 PM 1/20/2002]
The supercharger itself is rarely the problem. The problem is...greed. You gain so much power, you think you can squeeze out a little more. Safely, you can't, and you'll have no warning before your engines craters.
Do not raise your rev-limiter much if any.
Do not run too much timing.
Do not run too much boost.
Do not use cheap gas, and use 100 octane unleaded when you run more advance.
Detonation will end your motor's life. The normal rotational forces of an engine are harder on it than a supercharger, unless you exceed SOA. (If I have to explain what "SOA" is, you better not even think about a supercharger...)
I got 30,000 miles out of a Vortech S-Trim on an LT1, with no problems. The engine and s/c are still running, after five years of responsible fun.
Don't worry about being so repetitve. It often takes repetition before things sink in the average person's head anyway. I always look forward to your knowledgeable posts.
Can you please explain SOA? And yes, even though I am not familiar with that acronym, I am considering a supercharger - sorry for my ignorance.
There is excellent advice above. Anyone who thinks it will not decrease engine life should not put one on. You might get lucky, but hope for the best and plan for the worst.
One more note, read the new Motor Trend article on the upcoming supercharged Mustang engine. Very enlightening. Also, note that Lingenfelter generally changes out many internal parts on the engines that are tested on the pages of car magazines. Ever wonder why his cars never break in these tests, while many other tuner cars do? He does not send cars to be publicly tested that have not been strengthened internally.
[Modified by jschindler, 10:01 PM 1/31/2002]
