Trans, Diff, torque tube questions?
Old Jan 19, 2009 | 10:12 AM
  #41
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Originally Posted by Kurtomac
eh burnouts while holding the brakes wouldnt do that
my stock clutch held fine doing that
curious was your Slave cylinder shimmed
Yep I know, you and Brett are the two guys I was talking about when I said that I know other guys who hold the brake to do burnouts. The slave was not shimmed.
Cajun
Old Jan 19, 2009 | 01:11 PM
  #42
Kurtomac's Avatar
Kurtomac
weird...wonder if your slave cylinder was bad? not allowing the clutch to fully be released?
Old Jan 19, 2009 | 01:14 PM
  #43
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Don't think that was the problem since he was able to shift gears fine.
Maybe some bad clutch material, oily surface on it or weak pressure plate springs.
Old Jan 19, 2009 | 02:17 PM
  #44
0Cajun @ Edgyvette
Former Vendor
Installed new APS slave when the clutch went in about 900-1000 miles ago. Who knows
Old Jan 19, 2009 | 02:18 PM
  #45
0Cajun @ Edgyvette
Former Vendor
Hey brother how do I test for that? I have a buddy who has a clutch disk I can replace this one with but dont want the same thing to happen again because of another issue....................
Old Jan 19, 2009 | 07:55 PM
  #46
0Cajun @ Edgyvette
Former Vendor
Well I took my clutch plate and pressure plate to a buddy who knows his $h!t and he said that both are smoked. I knew the clutch plate was toast but now I am on the hook for a whole new clutch. This sucks MONKEY A$$!
I have called Jerrod at Textralia and sent him the pics of the clutch, plates, etc. I guess I will see what he comes back with. I have heard good things about them but dont know how they will handle this. I will update the thread when I hear back from him.
Cajun
Old Jan 20, 2009 | 04:49 PM
  #47
FASST LN's Avatar
FASST LN
Holy snikes!!
Can't believe this happened. The only way I could see this happening from the limited amount of time the clutch was in the car is if it was not fully engaging.
I agree, this would lead to shifting problems and such, but I can't imagine any other way...unless the X-grip was just overpowered all of the time, but I don't think anything with less than 500-rwhp would overpower an X-grip.
Old Jan 20, 2009 | 05:40 PM
  #48
bumble-z's Avatar
bumble-z
My stock clutch has held up to about 25- 30 passes, doing the same method of burnouts (in 2nd gear) over the last 6 yrs. Same original clutch, p/p, f/w. Good luck.
Old Jan 20, 2009 | 06:05 PM
  #49
0Cajun @ Edgyvette
Former Vendor
Originally Posted by FASST LN
Holy snikes!!
You know I did have some slight shifting issues into 3 and 4 gear but I figured it was just cause I was shifting at too high RPM (3-4K) or the shifter needed to be realigned. I aligned it once when I installed it and all was well until the clutch had about 500-600 miles on it. I figured the shifter had just slipped a little or something or I just sucked at finding the gears
Old Jan 20, 2009 | 06:07 PM
  #50
0Cajun @ Edgyvette
Former Vendor
I know many guys who do it repeatedly (20-30 times) with no issues. One guy has a stock clutch also. I dont know but I know I hate to waste money and that was a quick $1000 bucks
Old Jan 20, 2009 | 06:31 PM
  #51
Targa98's Avatar
Targa98
Holding the brake during a burnout would ABSOLUTELY not do that to a clutch. It will burn up your rear brakes, yes, but your clutch will not complain at all as long as it is fully engaged. To burn a clutch up like that you were either overpowering it, not fully engaging, leaking on it or something of that matter. It was not held still between the flywheel/pressure plate. Further inspection is required to find out exactly WHY, but I will bet my car that is has nothing to do with holding the brake pedal.
