date code stock battery??
Old Jan 13, 2009 | 10:24 AM
Marcs c5's Avatar
Marcs c5
Default date code stock battery??
I was looking for the date code on the AC Delco in my 03 Z and could not find it. Where is it located?
Old Jan 13, 2009 | 03:25 PM
Dave68's Avatar
Dave68
You might want to see if the current battery location is the same for yours:
http://www.acdelco.com/parts/battery...y-warranty.jsp
My OEM AC Delco AGM battery was 7 years old when I replaced it and it was still cranking the starter jus fine. Your battery may be approaching 6.5 years of age, so you may want to replace it, sometime this year or early next year.
Old Jan 13, 2009 | 09:25 PM
Marcs c5's Avatar
Marcs c5
I was thinking the same thing about replacing it soon.
Old Jan 13, 2009 | 09:53 PM
TEXHAWK0's Avatar
TEXHAWK0
Aftermarket batteries have a date code on the top label, but I am not sure all "factory" batteries have the code on them. Seems like I had a Camaro battery that I never could find the code on either.
The warranty date code is located on the top label of the battery. The first character is either a P or S. The next two digits determine the month, the third digit is year and the fourth digit indicates the manufacturing plant. For example, P 094N means the battery was made in September 2004 in the New Brunswick factory.
Old Jan 13, 2009 | 10:44 PM
BucksC5's Avatar
BucksC5
Cruising
Default date code
Most battery companies use a letter for the month and number for the year on the side of the battery, such as small round stickers. A would stand for January and 8 would stand for 2008.
Old Jan 14, 2009 | 06:35 AM
vsocks1's Avatar
vsocks1
The Oem battery in my 03 Z had to be replaced in November 07.
Time for a new one!!
To date code stock battery??
