Help!! Loud ticking nosie from the engine
Old Jan 14, 2009 | 08:16 AM
auburnsky's Avatar
auburnsky
Default Help!! Loud ticking nosie from the engine
2001 Z06 all of a sudden a loud ticking noise coming from the engine.
What could it be? Even when the car is on idle and warmed up the noise is quite loud.
Old Jan 14, 2009 | 09:13 AM
knyght4's Avatar
knyght4
it could be a bad lifter. Try searching "engine tick"
Also throw done some more specifics. How's the idle? Any stalling? What mods you have?
Old Jan 14, 2009 | 09:28 AM
YeloFevr's Avatar
YeloFevr
Is it RPM related? Half speed?
Old Jan 14, 2009 | 11:54 AM
auburnsky's Avatar
auburnsky
The car is stock ,just a borla exhaust and a tune. It drives normal, oil pressure is normal and so as temp. On the last oil change it was consuming between 1 to 2 quarts of oil.
Old Jan 14, 2009 | 11:56 AM
auburnsky's Avatar
auburnsky
It idles fine and it drives normal no hesitation.
Old Jan 14, 2009 | 11:57 AM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
In my minivan i also had the ticking noise was loud, the mechanic would always recommend some MMO( Marvel Mystery Oil) and it would quiet the ticking sound completely, i dont know if it will help, but figured i would just give you some info , good luck
Old Jan 14, 2009 | 12:12 PM
C5Natie's Avatar
C5Natie
Its better to fix the problem than to hide it with snake oils. Put a stethescope to the valve covers and find the noise. You might wnat to pull off the valve covers and look for and damage, bad lifter, pushrod...etc.
Old Jan 14, 2009 | 12:13 PM
Chuck A's Avatar
Chuck A
100% i just said that we did that for the minivan which is a POS the verte would get the full treatment, of anything it needed
Old Jan 14, 2009 | 12:25 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Could be a sticking valve too or maybe you lost a valve retainer clip. Of course, the first thing that comes to mind is a lifter as already stated. The lifter will usually pressurize and the noise will abate. But if it remains constant, I would suggest locating it first, pull the valve cover and get a quick look at the rocker. You could have lost the needle bearings in the rocker itself...has happened to people before.
Old Jan 14, 2009 | 12:59 PM
C5Natie's Avatar
C5Natie
Ive used old valve covers with the tops cut off to look at the valvetrain with the engine running. It keeps the oil from splashing out.
Old Jan 14, 2009 | 01:12 PM
corvettebob1's Avatar
corvettebob1
If you have the Magnacharger as listed in your profile it's not stock!
Now if you do have this mod I would expect you have upgraded valve springs meaning duals.
You may have broken a valve spring and the inner spring has saved your butt.
Find the problem before it finds your wallet!
Old Jan 14, 2009 | 03:42 PM
auburnsky's Avatar
auburnsky
The one with the maggie is a 99 FRC and the stock one is the 2001 Z06.
Old Jan 14, 2009 | 03:43 PM
auburnsky's Avatar
auburnsky
Thanks for the advise fellas, I think I will just bring it to the shop to be checked out.Thanks again !!!
Old Jan 14, 2009 | 04:14 PM
tcmc5's Avatar
tcmc5
An exhaust leak can make a loud ticking noise. Make sure your AIR tubes are tight and that there are no other leaks(crack?) from the manifolds/headers.
Old Jan 14, 2009 | 04:55 PM
redrckt97's Avatar
redrckt97
I'm wih TCMC5 ... check for exhaust manifold gasket leaks
or air tubes - my headers have small cracks where the air tubes
weld on and they make a distinct ticking sound. I also had a
(dual) valve spring break but it was Very obvious- ran terrible.
Old Jan 18, 2009 | 09:35 PM
Rick Perkins's Avatar
Rick Perkins
I hate to even ask this but: Did you change gas stations or gas? I bought my car and it was knocking when I got it. I think the previous owner put some regular unleaded in it. I got to a station where I knew the fuel quality and filled it up. The knock went away within about an hour.
Old Jan 19, 2009 | 01:52 PM
auburnsky's Avatar
auburnsky
Always put in chevron 91 octane here in CA. I just got it back from the shop and they said it's coming from the short block. I will get a 2nd and 3rd opinion.
To Help!! Loud ticking nosie from the engine
