NGK Spark Plug Questions....
A local auto parts store said the NGK TR5 is the plug for an 03 LS1, not the TR55.
Specs for TR5: G-Power Resistor Spark Plug
14mm x .708" Reach
5/8" Hex
Projected
Tapered seat
(No gap specified)
Specs for TR55: G-Power Resistor Spark Plug
14mm x .708" Reach
5/8" Hex
Projected
Tapered seat
.059" Gap
Then there is the TR55-1GP: G-Power Resistor Spark Plug
14mm x .807" Reach
5/8" Hex
Extended projection
Tapered seat
.059" Gap
I'm guessing the plug of choice is the TR55-GP w/o the extended reach?
Are you gaping these to .059 and not .040 like the factory Delco's?
TR55 is the same heat plug as TR5, just gapped at .055"
TR6 is one step colder plug, (also gapped at .040") commonly used with boost or high compression apps.
For most, TR55 is a good choice, we have the ignition power to make the larger gap work.
I went to the NGK website http://www.ngksparkplugs.com/ and didn't find the catlog you mentioned, I'll keep looking. NGK's site says to use the TR5GP as well not the 55 so thanks for clearing this up for me.
Thanks to everyone for all the great info!
I'm 90 RWHP over stock...I'm wondering if I should try the colder plug as I'm running approx. 10.75CR.
This whole spark plug thing started because I went to SEMA this year and met the Pulstar rep and he was nice enough to give me a set of Pulstar's to try out (ad1's).
There was nothing wrong with my stock Delco's but I finally put the Pulstar's in recently anyway, gaped them to the recommended .040. It might be my imagination but I thought my car felt sluggish, again probably my imagination. We have been having cooler weather so I've also been playing with my AFR (using HPTuners) at about the same time. So to clarify... I'm in no way putting any blame on the plugs.
So I figured I'd try some NGK's you guys have been raving about since they aren't too expensive. It's either that or put my iridium's back in again and see what happens.
For the last 7 years I have run the NGK TR55's, which are factory-gapped at 0.055, with good results.
DG
Seeing your setup and location, I would be inclided to use the TR6. Not sure what those other Pulstar plugs are, but I like plain ole copper core.
Here's a link to them: http://www.pulstar.com/
In an old thread TLewis did some dyno testing with them and actually came up with a small HP increase on stock or mildly tuned C5's/C6's.
