Harmonic balancer pinning
Old Jan 15, 2009 | 06:30 PM
brit2001's Avatar
brit2001
Default Harmonic balancer pinning
I'm getting ready to do a head and cam swap and thought that while I have the steering rack out of the way I would pin the balancer. Does any one make a kit to do this?
Thanks Laurence
Old Jan 15, 2009 | 06:42 PM
slothy's Avatar
slothy
http://www.aacorvette.com/performanc...&cPath=1_14_44
Old Jan 15, 2009 | 06:48 PM
vsocks1's Avatar
vsocks1
ATI makes a kit also that pins from the side into the balancer keyway if the balancer has one.
Old Jan 15, 2009 | 08:08 PM
brit2001's Avatar
brit2001
Thanks, that is what I was looking for.
Old Jan 15, 2009 | 10:34 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
Thanks Laurence
We carry them ATI Crankshaft / Harmonic Balancer Pinning Kit. They are in stock ready to ship.
Seth
Old Jan 19, 2009 | 12:14 AM
thetorch's Avatar
thetorch
Thanks Laurence
If your using an ATI damper, I would ONLY use the ATI pinning kit. The ATI kit pins the crank in a vertical position where the A&A pins the crank in a horizontal position. The ATI pinning kit allows the use of the standard 3/16" keyway in most aftermarket dampers. The A&A requires you to drill a new hole that's half in the crank and half in the damper.
To Harmonic balancer pinning
