Starting Problem
Old Jan 16, 2009 | 12:29 PM
Jamn's Avatar
Jamn
Default Starting Problem
I recently developed a starting problem with my 2001 Corvette. When I would turn the key, sometimes I would get a clicking sound, and at other times it would start OK. This made me think it was the battery. After replacing the battery, nothing has changed. Intermittently I still get the clicking sound, and after several attempts of turning the key it will start. What is the general opinion out there. Another bad battery, solenoid, or starter?
Old Jan 16, 2009 | 01:14 PM
LDB C5's Avatar
LDB C5
I would start by checking the grounds
Old Jan 16, 2009 | 01:34 PM
Jamn's Avatar
Jamn
I'm assuming that you mean the main battery ground at both ends,,,Correct? I can't think of any other possible grounds.
Old Jan 16, 2009 | 01:50 PM
Jamn's Avatar
Jamn
OK I read the IMPORTANT ELECTRICAL INFORMATION post and found the grounding points and issues. I'll try checking the connectors out. I not sure how much current could be passed through these connectors to supply the starter, but it's definitely worth looking at. It seems to be a great write up.
Old Jan 16, 2009 | 02:51 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Check the obvious things like the battery connections and the battery to starter connection. From there, where is the clicking??? Inside or engine compartment? If its the solenoid clicking you may simply have it dying on you. If its the TDR relay inside next to the BCM, is the security light on steady or flashing? If its on steady, your chip in the key was read correctly. If this is a manual transmission, it might be the clutch switch or the ignition switch.
Old Jan 16, 2009 | 08:15 PM
Jamn's Avatar
Jamn
Thanks for all of the suggestions. I looked things over real good, and found that the main battery cable on the starter was not very snug. It took an easy 3/4 of a turn to tighten. With all of the current used by the starter, this could be it. Time will tell. If I have to replace the solenoid, it looks like I will have to drop both sides of the exhaust to remove the starter (they are connected in the center). This could be a big project.
Old Jan 16, 2009 | 09:11 PM
PaintballaXX's Avatar
PaintballaXX
I had the EXACT same problem. If its not your battery cable then I'm very sure it could be your ignition switch.
http://forums.corvetteforum.com/c5-t...ch-repair.html
Follow Bill Curlee's instructions if you keep having problems. It will cost you like 5 bucks to fix and some of your time. You are going to have to take off your radio bezel first and instructions to do that are on the forum.
Old Jan 17, 2009 | 02:08 AM
Jamn's Avatar
Jamn
Paintballaxx: I saw that post. The fix looks easy enough, but there wasn't instruction on how to remove the key switch from the dash. Any suggestions?
Old Jan 17, 2009 | 04:17 AM
lucky131969's Avatar
lucky131969
Originally Posted by Jamn
If I have to replace the solenoid, it looks like I will have to drop both sides of the exhaust to remove the starter.....
If you do figure out how to remove only the right side exhaust, please post up instructions......
Old Jan 17, 2009 | 09:05 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Lucky,,,your something else. I got a charge out of that one. My first though was SAWSALL!!!
I had the same issue on my 02 Z. checked the clutch switch with an ohm meter, replaced the theft deterrent relay ignition switch was good etc, checked the battery connections (retorqued to 11 ft/lbs) and cleaned and tightened the starter wires...Still had the same issue. When it happened I could whack the starter with something and it would immediately start.. Turned out to be a bad starter solenoid.
$45 bucks invested on a new solenoid and problem solved. You need to get them from a starter repair shop.
Bill
Old Jan 17, 2009 | 03:36 PM
lucky131969
You shouldn't have said that....someone will try it
Old Jan 17, 2009 | 03:47 PM
LDB C5's Avatar
LDB C5
As long as they post the pictures
Old Jan 17, 2009 | 07:41 PM
Jamn's Avatar
Jamn
Too funny.. Looks like I will be in for a new solenoid. Hopefully dropping the exhaust will not be an issue (tough to remove hardware). Replacing the solenoid should be easy.
Old Jan 18, 2009 | 01:41 AM
lucky131969
Bill's advice is spot on, but take note, he had performed additional troubleshooting before reaching the conclusion of the solenoid. I suggest you get a wiring diagram and a DMM before replacing any parts.
Old Jan 18, 2009 | 03:15 AM
PaintballaXX
After you move all the bezels out of the way you can stick the key in the starter, turn it (don't know to what position, but you do have to turn it) and you can disconnect all the stuff behind the starter and it will just slide out.
Old Jan 18, 2009 | 09:19 AM
65GGvert's Avatar
65GGvert
"What we have here, is a failure to communicate."
Old Jan 18, 2009 | 10:20 AM
lucky131969
WTF?
Old Jan 18, 2009 | 01:58 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If your going to replace the solenoid your going to need to purchase a very small deep well socket to get one of the fasteners out. One of the solenoid fasteners is recessed in well and a standard socket will not be able to fit into the recess. The other two are easy to remove. I can NEVER remember what size the socket needs to be.
Old Jan 18, 2009 | 02:42 PM
PaintballaXX
What? I mean the key switch/ignition. Not the starter motor. He asked how to remove it.
To Starting Problem
