Prep before clearcoating my clear roof?
Old Jan 16, 2009 | 11:22 PM
jacobsjp's Avatar
jacobsjp
Default Prep before clearcoating my clear roof?
My clear roof on my car is peeling, so I've decided to sand and clear coat it. Is there anything I should do it to prep the surface besides just sanding, cleaning and painting?
I'm not a painter and I've never painted on Lexan before, so any help would be appreciated.
Thanks,
John
I posted this in the paint / body section a couple of days ago and didn't get any response, so I figured I give the C5 section a try.
Old Jan 16, 2009 | 11:27 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
After sanding, do you expect it to be clear?
Old Jan 17, 2009 | 01:47 AM
dbiddle's Avatar
dbiddle
its been done, But good luck on this job.
Old Jan 17, 2009 | 05:11 AM
lucky131969's Avatar
lucky131969
That's what the clear coat is for. It "clears" everything right up....duh
Old Jan 17, 2009 | 06:37 AM
bobc997615's Avatar
bobc997615
I'd get some Duplicolor "Adhesion Promoter" in a spray can to apply before the clear coat. Prevents the clear from peeling off the Lexan. It's a clear spray.
Old Jan 17, 2009 | 07:49 AM
jacobsjp's Avatar
jacobsjp
Thanks. That's what I was looking for.
Old Jan 17, 2009 | 08:00 AM
minitech's Avatar
minitech
Here is an option not brought up much but should be sometimes.
Drive down to the nearest auto body shop. Tell them the clear coat needs to be replaced and ask how much it would be to sand it off and shoot another coat of clear on. By them professionally.
Check the cost of that versus the cost of buying all the supplies and doing it yourself for your first time painting. Mine came out perfect that way for $130.00
And to answer the question if you sand it do you expect it to be clear: Yup.
Old Jan 17, 2009 | 08:35 AM
nickwfd92's Avatar
nickwfd92
I did mine back in Sept. I used a really good Dupont Clear and Adhesion promoter. The old clear coat was a B to get off but once I got it off it was smooth as glass. I sprayed on the promoter then waited for the flash time and then shot on a few coats of clear. It came out OK it had some orange peal. I did rewet sand and then buffed it out. I have a few marks in it so I will be redoing it in the spring.
Old Jan 17, 2009 | 10:24 AM
dgrant3830's Avatar
dgrant3830
I'm not trying to be a pain in the you know what, its just that I've never heard of this before... sanding a lexan clear top, then clear coating it to make it clear. Too me, I picture using sand paper on glass, scratching the crap out of it, spray on some clear coat and its back to picture perfect again. Somehow, that doesn't sound right too me. Yes, at some point in the manufacture of the lexan top, it had to be polished, somehow. I would like to know if what you are doing, is the proper method and what type of sanding, sanding material and so on, is all used.
Old Jan 17, 2009 | 03:34 PM
lucky131969
I was kidding Bro......
Old Jan 17, 2009 | 05:23 PM
jacobsjp's Avatar
jacobsjp
Basically I'll be doing this ...
http://forums.corvetteforum.com/c5-t...sh-how-to.html
But with the adhesion promoter step between the sanding and clearcoating.
Old Jan 17, 2009 | 06:12 PM
lionelhutz's Avatar
lionelhutz
I just did mine.
the coating is hard stuff and takes a lot of sanding to get off. I ended up using an dual action air sander on it. Quality sanding media helps keep it sharp.
The lexan is a static magnet like you wouldn't believe so it's hard to keep the dirt away. I'll likely end up sanding and re-coating my top in the spring to get the dirt out. Finding a shop with a new paint booth could sure help with the dirt.
The clearcoat really cleans up any scratch marks. It looks great afterwards. Clean the lexan first to get the dirt out of the sanding scratch marks though.
That adhesion promoter sounds like a really good idea but I didn't do it.
Peter
Old Jan 17, 2009 | 07:57 PM
bobc997615's Avatar
bobc997615
Use a tack cloth on all surfaces before painting. Removes all the dust that the Lexan might pick up.
Originally Posted by lionelhutz
I just did mine.
Peter
Old Jan 18, 2009 | 08:16 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I did mine w/o clearcoating it. I sanded and polished and waxed it and it came out looking great. Lot of work and a mess from wetsanding, but after polishing the crazing virtually disappeared. Now it is just wash, dry and rewax. Buff it out and it looks great.
Old Jan 19, 2009 | 08:38 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Believe it or not this is what happens.
To the OP, I did mine a few months ago. The factory cloating is not paint, I don't know what it is but 400 wet/dry paper didn't do anything to it so I started of by sanding with 60 grit dry paper being careful to sand in one direction only, after that I worked my way up to 400 wet. When I was done you couldn't see through the top but after clearcoating it's crystal clear.
Old Jan 19, 2009 | 09:47 AM
TioSterling's Avatar
TioSterling
they make an antistatic cleaner that you can clean it with before painting the panel, should help reduce some of the static electricity. If you want it black again just mix a little black base in your clear and spray that then spray clear back over it after like 15 min flash time.
Old Jan 19, 2009 | 07:27 PM
hotmerc's Avatar
hotmerc
I did the top on mine because of the hazy look to it when I bought it & this was the worse looking item on the car. I did all the prep work on mine & had a friend shoot it. I then 2000 grit sanded it & he buffed it out, still looks perfect after 2 yrs of use. Mine ended up costing me about $60 bucks, money well spent.
Old Jan 20, 2009 | 12:37 AM
lionelhutz's Avatar
lionelhutz
Ya, that coating is hard where it's still good. I didn't want to leave it except where it was already peeling because if the clear didn't stick to it or I could see the transition then it's a huge mess to sand off the clear and the coating. So, I started with 220 on a D/A and worked up with 600, 800 and 1200. I actually then tried a quick pass with a 2000 or 2500 and the top became fairly clear to see through. It wasn't really necessary though, probably nothing over 600 was. I'm just hoping the clear doesn't peel because I went too fine.
Peter
To Prep before clearcoating my clear roof?
