Fuel Gauge Problems
Old Jan 17, 2009 | 06:04 AM
jjsafety's Avatar
jjsafety
Default Fuel Gauge Problems
I have a C5 1998 with a fuel gauge that wants to quit sometimes. It is after I fill up and run for a while. The gauge goes down to empty and the check gauges light comes on. I can turn the car off and restart, and everything is working great.
Can anyone help in why and what I need to do to fix!!!
Old Jan 17, 2009 | 06:10 AM
homewrecker's Avatar
homewrecker
Use Techron before a couple of fill-ups.
Old Jan 17, 2009 | 06:26 AM
jjsafety's Avatar
jjsafety
Will Try!!!!
Old Jan 17, 2009 | 08:05 AM
65GGvert's Avatar
65GGvert
SEARCH fuel gauge and read all the others with the same problem, or read the sticky at the top of the page.
Old Jan 17, 2009 | 10:00 AM
holterhouse's Avatar
holterhouse
Tried techron on my low mileage 99 and it did not cure the problem.The dealer solved with a $1200,00 pump replacement.
Old Jan 17, 2009 | 10:34 AM
jjsafety's Avatar
jjsafety
OUCH!!!! I hope that it is not a pump, but the car still runs great, the only thing is that the gauge goes to 0, but does not effect the car itself....
Old Jan 17, 2009 | 12:23 PM
DeeGee's Avatar
DeeGee
Its caused by sulfur build up on the gauge sensors. If it's still intermittent thats a good thing. Stick with the Techron and it should work. it certainly did for me after only a couple of bottles. Its possible to do the sensor change DIY if it gets to that but Techron should be the solution. you might want to consider changing where you get your gas if its causing fouling. Try a Chevron or a Shell station.
To Fuel Gauge Problems
