Centerforce DFC Noise?
Old Jan 18, 2009 | 11:51 AM
ryanc440's Avatar
ryanc440
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Default Centerforce DFC Noise?
I had a 12" Centerforce DFC with an aluminum Fidanza flywheel installed this summer, replaced the pilot and throw-out bearing as well as the master and slave. After the initial break-in where the clutch engaged very close to the floor, everything basically feels like stock now, except for when it's cold outside. When I engage the clutch in 1st gear on cold mornings, or late in the day when the car has been sitting for awhile, I get this weird noise and slight vibration feel in the floorboard and shifter. The noise is kind of hard to describe, I wouldn't call it a grinding sound, but something close. Does this sound like clutch "chatter" that I've read so much about? Does anyone else with this set-up experience anything similar? Thanks for your help and suggestions.
Old Jan 18, 2009 | 12:16 PM
black 99's Avatar
black 99
Default Clutch
I get more of a clutch whine under a bind like on a slight incline. I dont think it is anything t worry about it. JASON
