Hood Ajar indicator switch
Old Jan 18, 2009 | 05:09 PM
mcgilles's Avatar
mcgilles
Default Hood Ajar indicator switch
My shop manual seems to indicate that there is a hood ajar indicator switch for export models only. can anyone confirm if this is true? if it is, is it possible to add this to a domestic model?
not even concerned with hooking it into the BCM for factory anti-theft or a DIC alert or anything like that (although that would be nice) I want to add it to an aftermarket alarm.
Old Jan 18, 2009 | 06:19 PM
byronhunter's Avatar
byronhunter
Bracket, hood ajar ind lp sw (export) #10285408
Switch, hood ajar ind lp sw---------Not Serviced
From parts manual that I have. But you have to think someone has a part # for it. From the illustration, it looks like it mounts next to the underhood fuse block. HTH
BH
Old Jan 18, 2009 | 07:46 PM
lucky131969's Avatar
lucky131969
Is there a way to release the hood without being inside the car?
Old Jan 18, 2009 | 10:43 PM
mcgilles's Avatar
mcgilles
to the user...no, but to a thief absolutely. the hood is fiberglass, they could break it open, pry it open, or as a common threat to many vehicles, if you know where it is, you can crack open the fender, slit the sheething, and use a pair of needle nose pliers to pull the hood release cable from the outside. as a matter of fact, I think the hood release cables are easily accessible to someone with small hands and who knows the car through the side vents in the fenders.
regardless of why, I just think that opening the hood should be something that sounds an alarm, even if it doesn't seem to be that great of a threat.
Old Jan 20, 2009 | 02:06 AM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
IMO u would be far better off with an aftermarket mercury switch
To Hood Ajar indicator switch
