160 t-stat in winter driving?
Old Jan 20, 2009 | 11:48 AM
guitar420911's Avatar
guitar420911
Default 160 t-stat in winter driving?
Is it safe to drive a tuned car with a 160 t-stat in the winter?
Old Jan 20, 2009 | 12:43 PM
vettenuts's Avatar
vettenuts
Do a search for "sweet spot" written by Evil Twin. Bottom line is no if the motor is too cold.
Old Jan 20, 2009 | 01:00 PM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
What are you seeing for coolant temps. on cold days?
Old Jan 20, 2009 | 01:29 PM
guitar420911
I haven't installed it yet and don't drive much in the winter but you never know. I'm trying to figure out if I should put a 160 or 180 when I flush the coolant and get a tune.
What temps can I expect in the winter?
Old Jan 20, 2009 | 01:37 PM
92mr2turbo's Avatar
92mr2turbo
I have a 160*F stat and ive seen cruising temperatures(60mph+) between 169-189*F in coolant temperatures when the weather is between 30-60*F outside. My fans are are not reprogrammed either. My car has a stock tune.
Old Jan 20, 2009 | 01:54 PM
David426's Avatar
David426
I have the fans programmed to come on earlier which helps in the Texas heat
.. Texas usually has pretty mild winters, even so the operating temps( 160 degree thermostat) never get up to a normal range on short trips around town.. Not good. I definately would swap mine out seeing you live up north in Ohio,, Easy job to swap stats out,, just my.02 cents
This is my routine here in Texas
1. Stock thermostat from November-April
2. 160 thermostat from May-October
Old Jan 20, 2009 | 02:05 PM
Bill Dearborn's Avatar
Bill Dearborn
You need to pay attention to the oil temp as well. On the highway in the top gears the oil temp can run below the coolant temp. You want the oil temp above 150.
Bill
Old Jan 20, 2009 | 02:42 PM
Corvette Don's Avatar
Corvette Don
Both my oil and my coolant get to 178 in winter on the hwy, A couple jabs of the gas and the oil gets to about 190 which imho is not enough to burn all the crap off in the oil.
Old Jan 21, 2009 | 09:32 PM
clif's Avatar
clif
This morning, the outside temp was 13 degrees! I have a 160 thermostat. The engine warms up up 160 fairly quickly. I saw it go up to 169. Not bad for 13 degrees. The heat felt good.
Old Jan 22, 2009 | 12:56 AM
thetaxman's Avatar
thetaxman
Old Jan 22, 2009 | 09:34 PM
Chevy-SS's Avatar
Chevy-SS
http://forums.corvetteforum.com/c5-t...ermostat.html?
There's the "sweet spot" thread...............
Old Jan 23, 2009 | 08:29 AM
03SpiralGray's Avatar
03SpiralGray
Originally Posted by thetaxman
The 160 degree thermostat question has been beaten to death.
I run a 160 year round, I'm just waiting for my engine to explode into a million pieces from using it.
Old Jan 23, 2009 | 09:18 AM
Chevy-SS's Avatar
Chevy-SS
Originally Posted by 03SpiralGray
......The 160 degree thermostat question has been beaten to death.......
MOST topics have probably already been beaten to death. You can't blame someone for asking. Many times I search prior to posting and I find answers. But even then, some of the posts may be 6 months old (or older) and there may be new information available.
IMO, it's good to re-visit a lot of these basic topics. I never knew about the "sweet spot" posts by Evil-Twin, so I was happy to find them. I never woulda found them if I hadn't looked at this "beaten to death" thread.........
When you notice a "beaten to death" thread, there is one very easy solution for you - AVOID IT!
Peace
Old Jan 23, 2009 | 03:12 PM
guitar420911
You live in TX so I doubt it gets below freezing very often so a 160 tstat isn't an issue. It goes below 0 here in Ohio on a regular basis in the winter and I'm not trying to ruin my engine.
To 160 t-stat in winter driving?
