Led Taillight Conversion Kit
Old Jan 21, 2002 | 05:20 PM
ACCURATE's Avatar
ACCURATE
Default Led Taillight Conversion Kit
Installed the tail lights with no problem ,, Instructions then say to reach under the dash panel ( btwn panel and floor carpet) on the right side of drivers area and find the wire harness wrapped with foam , and insert supplied pigtail w/flasher .. :smash: .. Can't find it.. anyone else installed this in a 2002 c-5
.. maybe I'm just looking in wrong spot .. Joe : : :cry
Old Jan 21, 2002 | 09:25 PM
ACCURATE's Avatar
ACCURATE
Default Re: Led Taillight Conversion Kit (ACCURATE)
Thanks Shawn .. managed to get it right .. .. What a major difference from the stock lights .. well worth the money !!! :jester
Old Jan 21, 2002 | 10:29 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Looks like you found it, you have to attack it from the rear end. Reach way up in the hole, almost to your elbow. Wiggle your arm around and you should feel it, a little flash light will help. Wash your hand afterwards, it gets a little dirty!
:cheers:
Mine works great!
Old Jan 24, 2002 | 08:32 PM
los7883's Avatar
los7883
Default Re: Led Taillight Conversion Kit (wallstAL)
Does anybody have any pics of what these lights look like? I saw a picture of them on another site and the pictures weren't that good. :cool:
Old Jan 24, 2002 | 08:55 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
St. Jude Donor '03-'04-'05-'06
Default Re: Led Taillight Conversion Kit (los7883)
los7883,
We have these LED taillight kits in stock and they make the C5 look different over any other set-up available.
They are also brighter than stock and light up faster over the stock lights when you step on the brakes.
You can see a bunch of pictures of the kit here:
http://www.stores.yahoo.com/corvette...7presc5le.html
Here is a lighted pic of the kit:
ENJOY!
Shawn
Old Jan 24, 2002 | 09:04 PM
los7883's Avatar
los7883
Default Re: Led Taillight Conversion Kit (L.A.P.D.)
How hard is it to install them?
Old Jan 29, 2002 | 03:59 PM
ACCURATE's Avatar
ACCURATE
extremly simple .. 30 min job .. ;)
Old Jan 30, 2002 | 09:27 AM
Fox's Avatar
Fox
Can't tell from the pics, do the lenses have built in reflectors? And are they DOT certified?
Old Jan 30, 2002 | 11:54 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: Led Taillight Conversion Kit (Fox)
You are thinking of a different prodcuct. This is a rapid flash controller for the brake light.
Old Jan 30, 2002 | 02:07 PM
Fox's Avatar
Fox
I'm asking if they meet DOT standards, and if the lens has a built in reflector (like a bike reflector). The reflectors are required by DOT and are necessary in order to be visible to other drivers when the car is parked on a street at night for example. All stock taillight lenses that are DOT compliant have built in reflectors.
Old Jan 30, 2002 | 04:10 PM
L.A.P.D.'s Avatar
L.A.P.D.
Supporting Vendor
Fox,
Yes, these taillights are DOT approved and have built in reflectors in them. They are the circular ring you see in the picture around the LED pattern.
Shawn
Old Jan 30, 2002 | 05:47 PM
Fox's Avatar
Fox
Anyone in the MD/DC metro area bought these? I would like to see them in person.
Shawn-Thanks, you answred my question.
To Led Taillight Conversion Kit
