Intake Duct..GRRRRR
Old Jan 21, 2002 | 05:21 PM
PaulaH's Avatar
0PaulaH
Former Vendor
Default Intake Duct..GRRRRR
Can anyone tell me how to take the Intake Duct (Stock) OFF of the air filter box??? I have the coupler off, and the band loose at the air filter box...but it will not move, budge , twist or pried off! How the #^LL does it come off???????
Thanks guys once again, for helping a girl out..
Paula
[Modified by PaulaH, 3:22 PM 1/21/2002]
Old Jan 21, 2002 | 05:25 PM
Mag Red Monster's Avatar
Mag Red Monster
Elite Member
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Intake Duct..GRRRRR (PaulaH)
Paula..............it's been awhile, but I believe it simply pulls off. I'd run to the garage and check but I put the old one up in the loft area.
My bad.I went out and there it was:smash: Try ininserting a small flat bladed screwdriver under the rubber collar that is on the factory air box. It may be just stuck.
[Modified by Mag Red Monster, 3:30 PM 1/21/2002]
Old Jan 21, 2002 | 05:28 PM
PaulaH's Avatar
0PaulaH
Former Vendor
Default Re: Intake Duct..GRRRRR (Mag Red Monster)
I would think it would pull off, but it will not budge...I can see the sleeve down into the intake duct....I am tempted to just sit myself on the engine and pull! haha
Old Jan 21, 2002 | 05:33 PM
Patches's Avatar
Patches
It's tough, but it will come off. As suggested above, use a flat blade and it'll pry off. I had to fiddle with mine before it finally popped off.
Ed
Old Jan 21, 2002 | 05:35 PM
PaulaH's Avatar
0PaulaH
Former Vendor
Default Re: Intake Duct..GRRRRR (Patches)
Ok, heading out there again! Thanks...will give you a report.. :mad
Old Jan 21, 2002 | 05:38 PM
4THTOY's Avatar
4THTOY
Be careful with this plan. when removing it from the duct, the band that holds it on will always break, and I have never found a dealer who stocks this part!
Old Jan 21, 2002 | 05:42 PM
YELLOHHH's Avatar
YELLOHHH
If you do, please take pics...
Greg
:cool:
Old Jan 21, 2002 | 05:44 PM
CFIVEM3's Avatar
CFIVEM3
Default Re: Intake Duct..GRRRRR (Buckmaster)
Pull, pull, pull! Unfortunately that's how it comes off.
That could be misinterpreted!!!
Old Jan 21, 2002 | 06:00 PM
PaulaH's Avatar
0PaulaH
Former Vendor
Default Re: Intake Duct..GRRRRR (CFIVEM3)
Not working..I am so short I have to about crawl into the engine compartment! Would someone fly in and do this for me?????
Getting a tad :mad :mad :mad
Old Jan 21, 2002 | 06:24 PM
RoliO's Avatar
RoliO
I have a hammer, chisel, and a hacksaw. I can swing by after work. :lol:
Old Jan 21, 2002 | 06:26 PM
Mag Red Monster
Elite Member
Paula........if I remember correctly ( I'll run to the garage...BRB)
Plan B...try shooting some WD 40 on it and try working a small screw driver around it...........the rubber must be a lil stuck. See if that works.
Old Jan 21, 2002 | 06:31 PM
chrislee2's Avatar
chrislee2
Cruise-In V Veteran
I used a longish cresent wrench as a lever to pop it out. Put it in on the side or in the middle (on the other side of the hood) and pry. It will pop out. There's two cone shaped rubber plugs that are sticking into the nose of the car. Don't be afraid to give it some muscle. Or use physics to your advantage and use a prybar...
Good luck!
Old Jan 21, 2002 | 06:36 PM
PaulaH's Avatar
0PaulaH
Former Vendor
Default Re: Intake Duct..GRRRRR (chrislee2)
Now I have the whole air filter & stuff out... or hanging there... problem is I can't get to it..short arms, ya know... Yes, I tried a hammer! Geezes, it cannot be this difficult...Is it this hard to get back on?????? I have been trying since NOON!
OK, WD-40 here i come!
Old Jan 21, 2002 | 06:42 PM
RoliO's Avatar
RoliO
Paula,
If you can't get it off then I will be happy to go over and break it off....err I mean help you take it off ;) It'll be a few hours tho. :) I need to take you something to have painted for me anyway. :)
[Modified by RoliO, 4:43 PM 1/21/2002]
Old Jan 21, 2002 | 07:04 PM
PaulaH's Avatar
0PaulaH
Former Vendor
Default Re: Intake Duct..GRRRRR (RoliO)
I give up... I can see this is gonna cost me!" ;)
RoliO, you got yourself a deal.... :bb
WD40 no help...
Old Jan 21, 2002 | 07:05 PM
jawski's Avatar
jawski
wait untill you try to put it back on, use some liquid soap to lube it. :yesnod:
Old Jan 21, 2002 | 07:27 PM
PaulaH's Avatar
0PaulaH
Former Vendor
Default Re: Intake Duct..GRRRRR (jawski)
Gee Thanks Jawski....Cannot believe this is such a project!
To Intake Duct..GRRRRR
Old Jan 21, 2002 | 07:34 PM
wwashing's Avatar
wwashing
I'm glad you guys who've responded know what Paula is talking about. I have no idea where she is having problems from her description. Too bad there is no picture. Removal of all the intake duct parts is extremely easy except for the MAF which is in there real tight.
There is one trick to removing the big plastic duct in that those studs that pin it to the radiator shroud must be pried up before they will release.
Old Jan 21, 2002 | 07:39 PM
RadarBlue's Avatar
RadarBlue
If you're talking about the duct between the air box and the throttle body, there are two screws that hold it to the radiator shroud (as it goes over the top of the radiator). After removing these screws, I've found that it's easier to remove the duct from the throttle body first, then the air box.
Hope this helps. :)
Old Jan 21, 2002 | 08:29 PM
PaulaH's Avatar
0PaulaH
Former Vendor
Default Re: Intake Duct..GRRRRR (RadarBlue)
OK, yes, it is released from the fan shroud, unplugged the hose going into the air filter box..all is apart except this little pluggie that goes int the intake duct.. trying to figure which part of it unplugs..as there is asection about 1" down..or if it just pops off where the wires are plugged in.. Then it will be free to come into the house! :cheers:
Thanks all, Yes I am heeding all this advise....even taking into account the old wives tale"No pull"...and am disregarding that and have been pulling..... :D :D
